LED or STOCK lighting
Old Feb 1, 2015 | 07:22 AM
davidwruth's Avatar
davidwruth
I bought the HD lights I like them better than phase 7 cuz they actually have lights on the bottom half of spots
Old Feb 1, 2015 | 07:27 AM
just plain john's Avatar
just plain john
I'm running two amps and was worried about current draw. I switched to LED's because they reduced the amp load to roughly half of what it was. I chose Truk Lites because they cost less ($338 for all 3 on Amazon IIRC), but they work great. Very happy with them, and with the reduced electrical load.
Old Feb 1, 2015 | 08:07 AM
BigWaterJim's Avatar
BigWaterJim
The Daymakers on my FTLRX are far superior to the lights that come stock. Cost to whatever ratio, I am seen so much more hat my wife doesn't want me to follow her while she is in her cage. Also the road is so much brighter in front and on the sides so cost=priceless.
Old Feb 1, 2015 | 09:41 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I have put LED lights on all of my bikes since they were made available several years ago. Better for me meant that I could see much better at night.
Old Feb 1, 2015 | 11:42 AM
mphamrick's Avatar
mphamrick
I have installed LED's on everything that lights up on my bike.
I went from stock to halogen lamps, as a result yes running lights and headlight was brighter. But after a period of time the low beam headlight connection evidently loosened and melted half of the three pronged plug.
I have installed the Trucklite version of the LED light. Amazon price for all three lights shipped to the house $409.00. Also had to buy a French headlight ring from J&P Cycles.
Old Feb 1, 2015 | 03:40 PM
HDchrome's Avatar
HDchrome
Back about 6-8 years ago when LED's were being made available as replacements for 1157 and similar bulbs, they really sucked. Not as much light and the pattern was much smaller. That probably started the bad-mouthing buzz for LED's. Sort of like the oil leaking HD's of the early 80's, and how many times do we STILL hear that crap?
Since then, LED manufacturing has greatly improved, and now LED's are the technology of choice in good lighting. Much brighter, whiter, bigger patterns, longer lasting, and 20% of the current draw of incandescent. There are still jokers out there making and selling crappy LED's, but buy a quality LED light, and you'll have better lighting than the old school stuff.
Old Feb 1, 2015 | 05:19 PM
03snake's Avatar
03snake
I have the HD Daymaker Reflector. Much wider beam and good side visibility compared to the Daymaker Projector. Both are VERY expensive but worth it to me. HD LED tail light. Custom Dynamics LED rear turns and front Dynamic Ringz running/turns. The front running light goes out and the center 24 amber LED's illuminate on the side you select the turn signal.
Picture taken on a very bright summer day:
Attached Thumbnails LED or STOCK lighting-ledhigh.jpg   LED or STOCK lighting-ledlow.jpg
Old Feb 1, 2015 | 08:13 PM
mkguitar's Avatar
mkguitar
Originally Posted by just plain john
I'm running two amps and was worried about current draw. I switched to LED's...
Hey John, the TL7 is at about 2/3 consumption of a 65W high beam- not half.
( 3.60 Amps vs 5.4 Amps- low beam 1.8 vs 4.5)
So you may not have the reserve power you thought.
you can check the specs from TL, then use an online ohm's law calculator to see where you are for power consumption.
Mike
Old Feb 2, 2015 | 06:16 AM
just plain john
Mike
Thanks Mike, I was speaking in generalities. My point being that for me it was a win-win switching to LED over stock.
Old Feb 2, 2015 | 06:24 AM
roadking2014's Avatar
roadking2014
Ohm's, Len's and Kirchoffs,,,dont we have enough laws already just on helmets and loud exhaust???? Sorry, just a little electronics lament humor....
