Left Turn signal blinks very fast
Old Feb 5, 2015 | 07:04 PM
Sandcrab's Avatar
Sandcrab
Default What weight
Originally Posted by IzzoQuazzo
Switch to a thicker viscosity blinker fluid.
So what weight would you put into the beaker?
Old Feb 5, 2015 | 07:14 PM
Jackie Paper's Avatar
Jackie Paper
Is your 09 TSSM turn signal switch and alarm different then my 04 since mine will not function with a LED in the back. It still thinks I have a bad bulb (low resistance and will only work with a resistor added in the line) Do you have a resistor in the line? Know the later model system will work with LED but not sure what year Harley changed it.
Old Feb 5, 2015 | 08:34 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
10W60 should do the trick.
Old Feb 5, 2015 | 09:00 PM
bigskyroadglide's Avatar
bigskyroadglide
Has to be a bulb or a short in the bulb wire
My 04 did it, my 12 CVO did it. Every time bulb Shot or bulb vibrated loose.
Leds in back on 04, still when front bulb went out fast blink. Finally got tired of replacing bulbs put leds in front plus load equalizer no issues
Old Feb 5, 2015 | 09:19 PM
Buelligan666's Avatar
Buelligan666
Originally Posted by Sandcrab
I thought you had the answer, so today I went down and and removed the bulb, and it was good. Just to be sure, I put it on my boat battery and hit the one contact and it lit up. I then hit the other contact and it lit up the brighter filament, and I kept it on there about 5 seconds to see if it would pull apart, and it didn't. So I removed the rear lens cover and all the LED lights work, none burnt out. So I am still looking for a reason. .
Do you have a load equaliser for the rear LEDs? I hooked mine up without a load equalizer. They worked ok for about a week. Then I started getting fast flash. I added an equaliser and all is good. I have since went all LED. I had to add another load equalizer when I changed the fronts over. As already suggested, clean the socket and try a new lamp.
Old Feb 6, 2015 | 06:52 AM
Sandcrab's Avatar
Sandcrab
Default What changed
The LED rear lights have been on for at least 4 years, and many thousands of miles/hours with no problem. The only thing different this year is I removed the main power 40A circuit breaker for about 50 days to replace my cams/lifters, reflashed my ECM with a FuelMoto tune, and then went riding on a nice day. The turn signals worked fine and then suddenly only the left started acting up.
When I turn on the left side, it blinks normally for about 3, maybe 4 blinks, then goes into fast mode. I removed the front bulb, cleaned off the dielectric grease, checked the bulb using my boat battery to see if it lit, and then put new dielectric grease and reinstalled the bulb.
So other than what I said above, nothing has changed that I can see would cause it to blink so fast.
OBTW, what is a load equalizer? Where does it go, where do you get one? What does it do?
Old Feb 6, 2015 | 07:31 AM
Sandcrab's Avatar
Sandcrab
Default 4 way flashers
Searched the forum and found a post that said to turn my 4 way flashers on for 5 minutes, which I just did, but that didn't help either. Still exactly the same.
Old Feb 6, 2015 | 07:34 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Time to trade it in! Once things start going South it's all downhill after that.
Old Feb 6, 2015 | 07:35 AM
SafetyMan's Avatar
SafetyMan
So did you try a different bulb?
They're like a buck.
Try a NEW bulb and get back to us.
Old Feb 6, 2015 | 07:36 AM
SafetyMan's Avatar
SafetyMan
OR...
Carry your boat battery while you ride.
