2011 FLHTK (limited) - w/ 10 3/4" Mayhen baggerbar install
my understanding could change with +4" cable doing factory routing in flaring but could get by with possible +2 or +3?
Stock cable 38667-08a is said to be @
25 7/16" (adjuster)
3 1/2" (travel)
62 11/16" Overall Stock length cable
Clutch Cable#38649-08a is also listed for this bike (if using sidecar)
so it must be longer then stock cable right?
...being on a budget this cable for the price would work great
but the searching has revealed conflicting results for the true length of 38649-08a clutch cable - Does Anyone Know?
-posted this in the past but after 125 views and no response thought ID try it one last time before committing - Thanks for you time
thanks for the reply - that's about what I've found on the search wagon -
there saying +2 and +4 but most are saying +3 seems nobody needed a reason to measure - thanks, should work for my application
