single disc brake conversion?
Old Feb 17, 2015 | 08:28 AM
Dmore1623's Avatar
Dmore1623
6th Gear
Fat spoke wheels specifically....allthough I have heard that the 21/18 setup handles well lol...decisions decisions
Old Feb 17, 2015 | 08:30 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by Dmore1623
Thanks for the Input guys I really appreciate it.....I can't seem to find any pics of an 18 inch wheel on the front with both rotors....If you can still see a majority of the wheel I think I would rather go that route...A good point was brought up about the low pro tires on the 21s and I think I'd rather stick with the bigger tire
18" front is stock on some touring Harleys, including the SG, I just bought one to retrofit to my Glide.
Old Feb 17, 2015 | 08:41 AM
Dmore1623's Avatar
Dmore1623
6th Gear
That's true I guess I didn't realize that with my bike being a little older....I guess some rotors that are more see through could be an option also
Old Feb 17, 2015 | 09:28 AM
Hogpro's Avatar
Hogpro
Former Sponsor
The fallacy of people complaining about poor ride quality is just that. A fallacy. Enough on that for now.
Swapping to a single disc specifically depends on the year and model of your bike and if it has ABS or not so provide that info and we can help.
Old Feb 17, 2015 | 09:39 AM
Greezey Rider's Avatar
Greezey Rider
Says the guy that sells big wheels for a living.....
The FACT is, a 21" tire hasn't got much of a sidewall and therefore, doesn't absorb as much energy from an impact with road surface anomalies as a tire with a higher sidewall, that's what causes the rougher ride.
We won't even get into the smaller "footprint" of a skinny tire and it's negative effect on handling on a big bike.
Removing half of your front braking power for "looks" is not very bright either.
Old Feb 17, 2015 | 03:18 PM
Dmore1623's Avatar
Dmore1623
6th Gear
I'm not worried about the roughness of the ride but more of the stability and cornering abilities
Dmore1623's Avatar
Dmore1623
6th Gear
2003 electra glide standard
Old Feb 17, 2015 | 03:38 PM
Hogpro's Avatar
Hogpro
Former Sponsor
On an 03 you need a single brake line from the master cylinder to the single caliper. For the lower legs you can either machine of the mounting ears for the stock caliper and chrome or power coat or buy a set of legs that are designed to take a single caliper setup.
Get a wheel configured for a bagger with a single disc. You will probably want to do a 9/16 master cylinder as well on that 03.
Old Feb 17, 2015 | 08:47 PM
cpunchedglider's Avatar
cpunchedglider
My bike started life with a 16".
Converted front to HD 18".
Then went to 21" front.
Does the bike now ride rougher?
Little, but I attribute that more to kit I used to lower the front than to to the "lack" of tire or side wall. Fellow rider has 21" with a different lowering kit, rides a lot better than mine.
Single disc?
Never! Instead I went to dual HHI six piston calipers. Stops awesome!
My two cents...
Old Feb 17, 2015 | 11:09 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
On a show bike, the single sided brake set-up may look good to you but on a real world every day ride around bike why in the hell would you want to reduce the braking power that may end up saving your life? That's just RETARDED.
