single disc brake conversion?
Old Feb 19, 2015 | 01:02 PM
  #31
Joe12RK's Avatar
Joe12RK
Originally Posted by somorkc
if you do go to a single disc, do you have to go to the 9/16ths master cylinder? I would think at higher speeds that the braking force would be preferred. at lower speeds ie.. parking lots, gas station and the like seems it would be pretty easy to lock up the front tire. someone had said in this thread or a recent one that you have to change the banjo bolt from two hole to single. didn't remember seeing two holes in the bolt. have a extra two caliper set up in the shop will have to ck. great discussion in this thread.
smaller m/c moves less brake fluid for same handle movement - matches up to only one caliper needing it.
FFeric
May 4, 2014 06:42 PM
boomscatty
Wheels/Tires
Apr 23, 2012 01:29 PM
hdpearson13
Aug 29, 2008 06:57 PM
AZ HARLEY
Aug 16, 2007 04:13 PM
CNC WHEEL GUY
Oct 19, 2006 05:20 PM
