Don't forget the air!
Old Feb 21, 2015 | 12:19 PM
  #31
Hogleyripper's Avatar
Hogleyripper
Originally Posted by Prot
I have an Evo. Will using synthetic air cause a leak?
Very simple question....but to answer that is going to take a lot of scientific research.
Old Feb 21, 2015 | 12:29 PM
  #32
mgmmgm's Avatar
mgmmgm
Always good to check tire pressure on a regular basis. A couple of pounds can make the difference in feel and handling of your scooter.
Old Feb 21, 2015 | 01:15 PM
  #33
tfi racing's Avatar
tfi racing
Originally Posted by OldPhat
No air in my tires. They put Nitro & Gin in them.
Sounds good,here is the gin I recommend...
http://www.islandspirits.ca/
Old Feb 21, 2015 | 01:32 PM
  #34
Frank the Real Biker's Avatar
Originally Posted by Chuck U. Farley
I had really good luck with last years air, so much in fact, I removed the air from my tires and pumped through a high carbon filter and packed in rinsed out Jack Daniels bottles and stored them in a dark heated room in my shop. I plan on refilling the tires and having as much fun or more with that same air.
Ya gotta be careful about using the same air for more than one or two seasons. The constant rotating of the wheel causes turbulence within the tire and the 02 atoms will get all their corners rounded off from the abrasion. Once the atoms are completely rounded off they can't be stacked on each other. The stacking of the atoms is what makes them put pressure against the inside of the tire. In other words, the air gets worn out. That's why tires lose small amounts of pressure over time, and why you need to periodically add new atoms that will stack up and not just randomly roll around in the tire.
Old Feb 21, 2015 | 02:07 PM
  #35
Oldcruiser's Avatar
Oldcruiser
My biggest worry is finding new seat slider bearing's for my 1990 flhtcu.
Old Feb 21, 2015 | 02:13 PM
  #36
wlibert's Avatar
wlibert
I thought they fixed the need to swap air on the '14 and '15 models. I'll check my service manual but I'm fairly sure the issue was fixed.
Old Feb 21, 2015 | 05:00 PM
  #37
Dsm Limited's Avatar
Dsm Limited
I'm pretty sure the Rushmore bikes need to have air from South Dakota.
Old Feb 21, 2015 | 05:07 PM
  #38
TSheff's Avatar
TSheff
Seasonal air, seat slider bearings, and the auto gap controllers on the factory mags. All good reasons to get all your check ups done at your H-D dealer. Pretty sure a guy that know a friend of my wife's brother said it happened to his cousins sisters husband.
Old Feb 21, 2015 | 05:39 PM
  #39
EG-2006's Avatar
EG-2006
Originally Posted by TSheff
Have you checked the 02 levels in your air?
I have no idea. My 06 EG doesn't have O2 sensors.
Old Feb 21, 2015 | 07:42 PM
  #40
leon anthony's Avatar
leon anthony
the warranty just expired on my rear sliding muffler bearing
