check your VIN- if you have a California spec model then you have a cat in the header...a cat will also show itself if the pipe is tapped with a pen...tink, tink, tink, clunk.
a stock no-cat header will be fine for your bike.
mike
Like Mike said, the '09 models had the catalytic converter in the mufflers, not the headpipe.
In '10, the cat came in the headpipe. An aftermarket header might be a little lighter, but I can't imagine it would perform much better in the areas you described as important to you.
So would decatting the headpipe have the same result as an 09 headpipe? Mine being a 12 with a cat. But wouldnt a DX pipe or fuel moto 2:1:2 head pipe with a full 1.75 x over pipe make a difference over a decatted headpipe, or just minimal?
Curious here, I just installed the fullsac 1.75 baffles and am thinking of doing the headpipe with the X and x over pipe for better flow on my 110.
Leave the stock CATless headpipe....There will be no real noticeable gains by going with a new headpipe.....Spend that money on something else for the bike
Remember the '09 bike was a 96", while yours is a 110". I remember reading some FM posts that the bigger cross over would only show gains on big builds.
I am very unfamiliar with the characteristics of a 110". The large cross over might make a difference in your bike. I imagine the catless pipe probably definitely would.
2012 Roadglide I used the Fuelmoto 2-1-2 headpipe with a stage 1 download and nothing else. A little cooler, a little better throttle response and a little more sound. It worked for me.
I have a '09 103" with 255 cams tuned with SE tuner.
I currently have stock headpipe with 3.5" Rinehart slipons.
Im looking to change to 4" Rineharts so i cant decide to go with slimeline duals or something like Fullsac DX pipe or just leave the stock pipe and put on the new slipons.
What you guys think?
Unless your bike is a Calif. model you do not have a cat. That being said, go to the FuelMoto site and check their dyno runs. One dyno run was a stock '09 103 and one was exactly the same, but with a FuelMoto head pipe. There was 1.8 HP difference. That is not much gain for the 400.00 asking price.
Bill
I'm with bill, I own a 2013 and it has a cat in the header..........I went to HD this weekend to talk about buying a header without a cat and the cost of the headers/slip ons was just not worth the extra couple hps. That $$ will be well spent on a bike trip this summer
Bill
A agree, there isn't enough gain to be had for the cost. A stock head pipe without a cat works just fine on a stock to mild build.
