Checking Tire Pressure
Old Mar 6, 2015 | 03:33 PM
  #61
roadking2014's Avatar
roadking2014
Im OCD. I cant get off my bike unless both valve stems are down and all the numbers on the odometer match.
Old Mar 6, 2015 | 07:57 PM
  #62
osudvm's Avatar
osudvm
Originally Posted by cass
looks like that might just be the ticket. i sometimes have problems keeping the chuck tight against the stem. this would certainly solve it. will have to take a trip to the stealer.
I have this extension too and it really does make it a lot easier. I still think it is very smart to check your tire pressure before every ride so making it easier to do will also result in better safety.
Old Mar 6, 2015 | 08:21 PM
  #63
CSMHOG's Avatar
CSMHOG
Originally Posted by KCFLHRC
Yep, we had two fatalities in two separate accidents due to low tire pressure. I can't beleive I'm reading that some only check their TP several times a year. I've heard of technicians finding tires 10 to 15 lbs low. Unbelievable. I check mine weekly, sometimes more. Yes, laying on the ground is a pain ... But sliding along the ground at 60 mph hurts worse. If you want your tires to behave correctly under pressure and stress in a panic stop or maneuver, it's wise to check your TP often.
Old Mar 6, 2015 | 10:08 PM
  #64
RickLB's Avatar
RickLB
Originally Posted by GTK
HD sells a tire access extension hose which works pretty slick.
This^^^^
Redlegvzv
Jun 8, 2014 07:09 PM
danrad55
Aug 9, 2012 04:27 PM
gli.der
Aug 16, 2010 09:35 PM
davessworks
Dec 24, 2009 09:22 PM
Thundr56
Wheels/Tires
Jul 8, 2009 07:31 PM
