She's leaking
Old Mar 2, 2015 | 11:26 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Good luck dude shouldn't be to bad!
Old Mar 2, 2015 | 12:18 PM
glenc's Avatar
glenc
Originally Posted by mkguitar
if you have torx bolts, the size is T27.
T25 will "fit" until you apply torque, then they strip.
It sounds like your bike needs a good going over with manual in hand to ensure that you don;t have anymore surprises.
the manual will also have torque values so that none of the bolts break
mike
Thats the plan this week. Have some good weather next week so gotta make sure everything is good to go.
Old Mar 4, 2015 | 08:30 AM
glenc's Avatar
glenc
Well all the bolts were tight. It appears to be leaking from the primary cover in two places at the bottom. I guess my next step is to replace the primary cover gasket? I have one on the way so hopefully that will do the trick. I looked everywhere and could find no oil leaking anywhere else.
Old Mar 4, 2015 | 08:41 AM
96roadking's Avatar
96roadking
On my 1996 Road King I had the main transmission seal go bad, but I think you'd see more oil then that. It literally poured out when it was warm. Do not overtighten bolts in those aluminum cases! I'd much rather deal with gaskets then stripped holes!
Old Mar 4, 2015 | 09:51 AM
mkguitar's Avatar
mkguitar
oil will always move to the lowest point...which on our bikes is the inner edge of the primary ( when on the jiffy stand).
a slight seep can be hard to find- spray on foot powder ( 99˘ store) will help find a seep, spray in on and see where it gets washed away
echo !
Old Mar 4, 2015 | 10:27 AM
mrfikser's Avatar
mrfikser
my experience is that primary covers don't leak very often ...sometimes but not often... I would run my hand between the inner cover and the engine on the back side of the inner cover and make sure it is not leaking there ...just a heads up...yours cover might be leaking, but I would just give it a real good look see to make sure you replace the right part...
Old Mar 4, 2015 | 12:05 PM
risuperglidecustomman's Avatar
Run your finger along the bottom of the primary cover & case, if you feel oil Bingo. If not check the bolt underneath & rubber gasket. Good Luck!
Old Mar 4, 2015 | 03:25 PM
bklynbob's Avatar
bklynbob
What year/ mileage?
Old Mar 6, 2015 | 08:36 AM
glenc's Avatar
glenc
Originally Posted by bklynbob
What year/ mileage?
Its a 98 Road King. It has right at 61000 miles on it. No engine noise. Runs great. The leak started after sitting for about 2 weeks
Old Mar 9, 2015 | 12:03 PM
glenc's Avatar
glenc
After further inspection it looks like its leaking from the rear of the primary. I am taking it in to a friends shop tomorrow and have him check it out.
