Well It all started with me lookin under that timing cover to check them there cam guides (Needed to be replaced)! Asked a question on that got some great feedback and decided to go with removing the rocker boxes vs adjustable pushrods. (thanks for the feedback) Got it done last night jumped on it to go for a 30 mile ride got into 10 of it and i smell oil burning!!! I look at my right leg and it is full of oil as well as the bike!! Turned around and got on here and did some searching!!! Found out about alighning oit pump and did so today and it worked so far on a 10 mile putt!!! Thanks this is one great site and a great learning center for us!!!
I'll second that, too. Put a powered antenna in the fairing today. Thanks to the folks here I knew exactly how to remove the fairing (along with the helpful hint of covering the passing lamps with socks), and unplug the headlamp. Then, knew exactly which wires (already in the headlight bundle) to tap into. Lot of useful info around here... thanks.
This is the GREATEST HD forum. Just when you think you know everything...someone has a better way to do something! I always read and read and read the input on this forum!
Uh, hope I'm not stepping out of line here fellas, but if you find this forum as useful as you say you do, I know a contribution of any amount to the forum operators would be appreciated. I donate every year in Janurary and it's a well made investment for the reason(s) you folks talk about.
If the forum saves you big bucks please consider parting with a few of them (No, I am not affiliated with this forum in any way) to make sure the information keeps flowing.
