Cams on a 96 motor?
Given the tremendous bottom end, does the 48 fall off pretty fast, or can you run it out to the top of the gear?
My decision's been made, the Wood 555s are enroute. The journey continues...!
I also ran the 204's in the 09 96" motor for about 52k and liked them. The only issue that I had with them was they were a little flat on the bottom 2up. 2800rpm they come on strong and pull out until the heads run out of air. They also have that idle that people look for. Ideally these would be great with a compression bump but if you're going that far then well.....
its a bone stock 96 with AC, FM headpipe, dynojet PV with FM tune and bassani 36" cholos, not exactly a hotrod, i get that I lose power with that pipe setup, but I like the look.
I wanted something with power more so on the lowend, I do the occasonal 2up and mountain rides, I read these forums extensively, and figured S&S551 was my best option, although its not the most popular around here, Im really really happy with it, I dont have a dyno just yet, and it needs to be fine tuned, so itll only get better once that happens .Again, its no hotrod .....
