Point cover?
Old Mar 6, 2015 | 08:51 AM
kountry's Avatar
kountry
Originally Posted by grbrown
You have to carefully drill through the head of each rivet with a 1/8" drill bit. I use a hand-turned hand drill, not an electric one, as the rivets are very thin and don't require much effort to remove. To refit you can simply use screws through both the outer and inner cover, however the inner screws are at 90 degrees to the rivets. rwhisen's bike has probably already had that done to it.
For future reference we have an Evo section, where you can meet fellow Evo owners, who are well up to speed on these older bikes!
Thank You for your help. I don't know much about his bike and where it actually fit in with the touring world. I do appreciate your time though.
Old Mar 6, 2015 | 09:00 AM
SBates08's Avatar
SBates08
Maybe this will help. At least you can see how it breaks down.
2010 Limited with some stuff!!
Old Mar 6, 2015 | 12:35 PM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by kountry
I believe its a timer cover.
Indeed, there's a sensor inside that does a similar job to points.
Mchad
EVO
16
Jul 5, 2018 05:25 PM
darrellv
Nov 9, 2017 08:21 AM
JimmyL
Feb 26, 2017 02:52 PM
boxcar
Jun 30, 2007 08:17 PM
