2013 front calipers on a 2007?
Old Mar 10, 2015 | 06:06 PM
scottma978's Avatar
scottma978
Default 2013 front calipers on a 2007?
Does anyone know if a set of 2013 Brembo front calipers will mount right up to my forks on my '07?. I have always hated the quality of the braking on my bike and have a chance to get a set of stock Brembos. Both are non ABS, so that at least, should not be an issue.
Old Mar 10, 2015 | 06:51 PM
lt1-xjs's Avatar
lt1-xjs
They will bolt right on. You'll need the '08 up rotors and brake line also.
Old Mar 10, 2015 | 07:03 PM
Sailrider 1's Avatar
Sailrider 1
And the 08 and up master cylinder.
It will work with your 07 master cylinder but it's smoother with the 08 and up master. I have Brembo's on my 03 Road King and my 07 Road King. On the 07 I changed the master cylinder to an 08 and up, on the 03 I used the 03 master cylinder. The 07 bike stops much better and smoother than the 03 and the only difference is the master cylinder.
Old Mar 10, 2015 | 11:31 PM
bagman1's Avatar
bagman1
I was told the rotor bolt pattern is different, so you will need the newer wheels?? No! and they have the 25mm axle and bearings vs 07 had the 1" bearing/axle. I thought of it when I had my 07 but it was going to be very costly, needless to say, I skipped that mod.
Old Mar 10, 2015 | 11:52 PM
lt1-xjs's Avatar
lt1-xjs
Rotors are the same except for the diameter, 11.5" vs 11.8".
goldie
Apr 6, 2014 10:04 AM
Trunk Monkey
Apr 5, 2014 04:47 PM
POPASICKBOY1
Aug 20, 2011 08:53 PM
spaceblue
Wheels/Tires
Nov 19, 2010 03:19 PM
djw
Apr 26, 2008 07:01 AM
