08 and up caliper questions
Old Aug 20, 2011 | 06:02 PM
POPASICKBOY1's Avatar
POPASICKBOY1
Default 08 and up caliper questions
Is there a different caliper for abs than non abs for front touring bikes ? What is needed to upgrade to use these calipers on my 02 roadking? I know a different front master cyclinder. New rotors are bigger but can I use my rototrs?
Old Aug 20, 2011 | 06:23 PM
dawg's Avatar
dawg
WVUltra has a great write up on doing this. Calipers are the same for ABS and non ABS. You will need rotors and master cylinder change
Old Aug 20, 2011 | 08:53 PM
Mike's Avatar
Mike
The 08 rotors are a slightly different size, so you'll want to change those. You can run the older master cylinder with the Brembo calipers, but a big part of the increased braking with the brembo calipers comes from the larger master cylinder. You need the newer brake lines with the larger master cylinder due to the increased pressure.
I have heard that you can also just run the newer master cylinder and updated brake lines with the older calipers for a pretty good boost in braking. Never tried that, so I couldn't vouch for the acccuracy of the claim.
Dynaglide92
2014-2024 Touring Models
Dec 25, 2018 07:17 PM
rebeltruce
Sep 23, 2017 08:07 AM
hajones98
Oct 2, 2012 02:56 PM
Chopperguy99
Wheels/Tires
Aug 19, 2011 11:58 AM
jarhead45
Feb 9, 2009 09:58 PM
