Guys I'm having trouble getting my turn signals to sync after I changed over to LED on my 2010 Ultra.
I have a custom dynamics street magic load equalizer and the instructions say to press the right turn signal on and let flash twice, then do the same for the left and then let the right flash 10 times.
The right signal doesn't seem to want to sync. It will flash 5 times normally then flash fast.
I just resynced my 09 SG tonight. I had the same problem. I talked to CD and they were a big help.
1, Disconnect your neg battery cable for the BIKE.
2, After 10 minutes reconnect the battery and perform the sync per instructions.
If that fails to work then,
1, jockey the turns signals 1 blink per side for between 10 and 15 times ending on the right blinking.
If that fails to work then jockey back to the left signal and just let it blink. This step is what re synced my signals. Good luck.
