Harley OEM Heated Grip Help
How did you bench test he left hand grip alone? According to my manual without the right grip connected this should not have worked.
Like I said dont really know this might help - good luck
I started to put things back, I hooked up the 12 volt 10 amp (that is important to know for future people) I connected the left and the right and fed power from where the grips get their power from the bike. The left hand heated up, but not the right hand. Urghhh.
I read the above post from Weatheredge. I would have never thought of that if he hadn't posted. I shook the right hand grip and it rattles. I thought great the gear in there for the TBW was also bad. I shined a flashlight down the tube to see what Weatheredge was talking about.
So then I took off the end cap, (simple pull out by finger nails) and straighten up the pins. Apparently when I installed the Khrome Werks 2+2 handlebars I didn't know about these pins and just shoved the grip back on.
There is a spot on the end of the TBW that these little pins insert into, then the cap goes back on.
However, I thought I had ruined that little circuit on the end. I left it dangle and and plugged it in, hooked up the TBW under the fairing, connected the interconnect heated hand grip wire (black an white) and then fed my 12 volt 10 amp power source (battery charger actually, and this is important to the end) I only got heat in the left grip again. Dang.
I thought well I will have to go to Harley to get another right hand grip because I want my heated grips.
I put it all back together, then took it out for a quick spin around the block, wall dang, not expecting it halfway around my hands were getting warm!
I would guess. That the bike has to be running and above idle to deliver enough amps to the grips to heat them, and enough power to heat the other side. The 12 volt 10 amp battery charger was not producing enough amps I would guess. I know this bike has a 50 amp charging system so that maybe why it didn't heat the other grip.
So the moral is...If you install new handle bars on your Electra Glide Touring bike make sure to take off the right hand end cap, and when reinstalling the grips to put that plug in place after the grips have been put back on so you don't bend those little pins.
Thanks to every one for your suggestions.
I read too that if they are disconnected they wouldn't work, but I thought I would try I had nothing to loose.
