Thundermax firmware update
Old Mar 16, 2015 | 11:00 AM
Buiceman's Avatar
Buiceman
Default Thundermax firmware update
With the latest firmware update, did Thundermax remove the feature that allows you to set the number of engine rotations before it receives fuel/spark?
With that feature set to 1, my bike fired right up. Since the firm ware updated, it's gone back to the old sluggish startup. And now I can't find the feature in the basic settings.
Old Mar 16, 2015 | 11:05 AM
mkguitar's Avatar
mkguitar
I don;t know about updates, but I suggest that a couple of spins before firing is a good thing.
our motors don;t have much of a flywheel, so a couple of rotations to get momentum is preferable.
mike
Old Mar 16, 2015 | 11:41 AM
journeyman's Avatar
journeyman
Compression Release delay is found in the Basic Settings area of the Module configuration. Mine is at 2 revolutions.
Old Mar 16, 2015 | 06:39 PM
Buiceman's Avatar
Buiceman
Journeyman, have you done the Feb 2015 firmware update. I'm regretting that I did. With the new update, compression relay delay is deactivated and in the box states "N/A This Firmeare". Has anyone had this issue? I can't be the only one who updated their firmware this year.
Thanks
Old Mar 16, 2015 | 08:04 PM
JAKE 2544's Avatar
JAKE 2544
Default TMAX firmware update
[QUOTE=Buiceman;13814138]Journeyman, have you done the Feb 2015 firmware update. I'm regretting that I did. With the new update, compression relay delay is deactivated and in the box states "N/A This Firmeare". Has anyone had this issue? I can't be the only one who updated their firmware this year.
I just installed the TMAX on my 14 FLHXS and did a firmware update prior to it. Just emailed tech support to inquire about the ACR,s and the rear cylinder cut out when hot. I want to make sure both are active and properly working through the TMAX. I installed a SE tuner on my 12 to find that the ACR,s were disabled after installing that tuner. I had hot start issues so brought it to the dealer. That's when they found them disabled, they were enabled prior to the SE tuner install. All was good again and no hot start issues when they put them back to enabled. I'll post back when I hear something from tech support.
Old Mar 18, 2015 | 11:27 AM
journeyman's Avatar
journeyman
no updates for me yet this year, good to know what you found.
Must be an oversight, let us know how this goes with tech support.
toddskill
The Dyno Room
35
Apr 27, 2019 04:09 PM
speakerfritz
Feb 21, 2013 09:42 AM
CobraEd
Sep 25, 2012 10:01 AM
ubreal
Aug 7, 2012 01:40 AM
user 37474839
Sep 21, 2007 08:20 AM
