6 digits
Old Mar 22, 2015 | 03:14 PM
  #31
Terryjft's Avatar
Terryjft
Originally Posted by howitzer88
And now the question: What oil do you use?
OIL THREAD HIJAAK????
Well...I bought the bike as a leftover in 2010, part of the sales deal was 3 years of maintenance for FREE (what's in the book... add for any extras like syn oil) So, I was cheap and stuck with dino oil for the 1st 3 years (about 60k). I think I got my monies worth on the service promotion.
When I took over maintenance I switched to Mobile 1 VTwin.
Old Mar 22, 2015 | 03:27 PM
  #32
Terryjft's Avatar
Terryjft
Originally Posted by CSMHOG
hahaha ... I have to second this comment! Congrats!! It would be interesting to hear of your maintenance / repairs over the last 100K. Wishing you many, many more miles!!
After experimenting on past rides, I've stuck with Dunlop tires and am thoroughly impressed with their performance and lifespan. Aside from the motor oil, I run Redline shockproof in the transmission, and rotella in the primary. I do 5k change on the motor and 10k on the other two fluids.
I had an inner primary bearing failure early on, and have replaced in several more times whenever it has been apart. I upgraded the clutch and spring somewhere along the line, installed the 255 cams.
Last summer, I had a transimission seal leak that was on the main gear which requires dissassembly of the transmisison. After looking at lots of options, I ended up getting the trans rebuilt by Baker for less than I could have done it for (with cost of tools etc.), and upgraded the compensator while in there (I think the comp failure contributed to the trans failure). Replace a stator just after that
Since the forks were due for the 50k service, I upgraded the front end this xmas.
One interesting thing...when I had the primary off for the cams/compensator, I did notice that the shop that had done the previous IPB job did not put in the circlip correctly (blocked the oil journal). This kind of thing is mainly why I do my own work. I would really prefer not to.
Lama
Dyna Models
Apr 8, 2012 12:16 AM
Just Dave
"The Florida Crew"
13
Dec 11, 2009 10:35 AM
kelhogan
Dyna Models
May 26, 2009 04:20 PM
