Screw me
Old Mar 25, 2015 | 02:01 PM
Buelligan666's Avatar
Buelligan666
Update: The good folks at New Castle Harley are going to refund me the cost of the bolt kit. That frees up some money to buy the machinist beer. I sure hope he gets it out easily. Thanks for the moral support yins guys.
Old Mar 25, 2015 | 02:27 PM
RaceFace's Avatar
RaceFace
Make sure you join your machinist for that beer too!!
Old Mar 25, 2015 | 02:29 PM
Buelligan666
I'll be partaking in that for sure. Plus a little Jack too.
Old Mar 25, 2015 | 02:48 PM
Joe12RK's Avatar
Joe12RK
so did you change the title or did the moderators? lol good luck fixing it
Old Mar 25, 2015 | 02:52 PM
Buelligan666
Must have been the mods.
Old Mar 25, 2015 | 03:29 PM
batman.'s Avatar
batman.
Nothing wrong with a lil old #7.
Batman
Squire.
Old Mar 25, 2015 | 03:43 PM
SunCruise's Avatar
SunCruise
Be careful twisting the cap on that #7.... don't wanna twist the #2 out of it
SC
Old Mar 25, 2015 | 04:39 PM
Vernal's Avatar
Vernal
The last couple broken bolts I worked on I drilled a short pilot hole then used a left hand drill bit and they came right out. So much easier than using easy outs.
Good luck
Old Mar 25, 2015 | 05:01 PM
wscott's Avatar
wscott
So last night I was changing my trans covers to the new black ones I got. I bought a Drag Specialties black chrome bolt kit. A couple new bolts were a little tough starting. I chased the ends with a die. Started easier seemed to go in fine. I did the side cover first and installed my new longer clutch cable. Them on to the top cover. Same deal little stubborn starting. Chased the ends with a die. Ran a tap in the holes to clean out the factory thread locker. I was making sure the bolts would go in fairly easy. As I started backing one out it got tight to turn. I stopped. Ran it in a little, started to back it out. In, out, in, out, in, out, in, SNAP!! A lot of cursing. I was so pissed!! I stopped for the night. I did enough damage. My friend is a machinist. He's gonna see if he can extract it for me. Those bolts are junk IMHO. I removed them all and contacted the folks I bought then through. I sure hope they give me some money back. I'm sure it's my problem now though. Needed to vent.
Have seen that happen when people were trying to install aftermarket parts that turned out to be an issue with either fine vs med thread and or an issue with std SAE vs Metric thread.
Scott
Old Mar 25, 2015 | 07:18 PM
themensh's Avatar
themensh
Look at the money you saved doing it yourself!!!!!!!!
