Ohlins 3-3 VS Harley Premium adjustable shocks
Old Apr 6, 2015 | 12:14 PM
Bmusg's Avatar
Bmusg
Originally Posted by wrenchguy24
This thread is not intended to Bash anybodys product or any Person related to selling them, Its to tell my personal findings.
History
2010 Ultra stock front suspension seat cut down by mean city cycles
rear shocks Ohlins 3-3
Rider 165 pass 120
When I first got the shocks got them set up I was like OMG these ride rough as hell, yes sag was done like seller said.
Got seller on the phone, I then placed a plastic tie strap on shock arm
and rode down the road and back this is with collar almost to the very top.
I told him the strap bareley even moved, those springs are to Stiff!!!!
Really that's what im saying, he sent me 2 more sets of springs.
after trying both sets I settled with Yellow set, I don't remember the spring rate.
Now the very best I got the ride was SOLO collar about 1/8 from top
and 40 Pounds of sand in plastic bags in saddle bags.
I wanted the bike to sit low as possible vertically Challenged 30 inch in seam. With this set up there is one particular rode that I ride on occasionally had these heaves in the pavement it would bounce me off the seat.
Now 2 up bike loaded it rode perfect.
Now new bike 2015 Ultra LOW with Harley premium adjustable 12 inch
shocks
Shocks are on setting 1
I am completely flat footed on this bike
Now when I ride this same exact rode
Bike does not bounce me off the seat, do I feel these same bumps of course night and day difference.
This is SOLO
today was the first time I got the wife on the bike
shocks are still set on setting 1 did not bottom out or anything rides
excellent.
I always herd about the WOW factor from the Ohlins shocks but I never
experienced that at all.
I still think the spring rate was wrong for my weight but the seller said this should be the best.
This Ultra LOW rides Night and Day better than my 2010 ultra ever did !!
I gotta ask...what is the 40# of sand in the bags for?
Old Apr 6, 2015 | 12:18 PM
wrenchguy24's Avatar
wrenchguy24
Adding another 40 pounds seemed to make it ride better!!!
I just don't think theses were the right springs for a 165 pound rider
Old Apr 6, 2015 | 12:32 PM
Bmusg's Avatar
Bmusg
Got it. I was wondering if that was part of the normal tuning procedure.
Old Apr 6, 2015 | 12:38 PM
FlaHeatWave's Avatar
FlaHeatWave
Another fan of the HD Premium stuff (f&R) here!
'Ride 2-up 95% of the time on this bike ('09 SERG), did the rears first, then the front, once the front "settled in" at 500-700 miles, played with the rears a couple of times, I see no need to adjust anymore (solo or 2-up.)
'Have >25k on the HD Premium and am still very satisfied with the ride / handling. The '09 rides / handles at least as good as my Bud's '15 CVORGU that I rode the other day...
Old Apr 6, 2015 | 01:10 PM
tj316's Avatar
tj316
I have owned many different shocks and have ridden my friends Road Glide Special with the new hand adjusted shocks . The Ohlins are worlds better than the Harley shocks , with that being said those who did not have that experience I'm 100% positive your shocks were not set up or adjusted properly . Your spring rate could have been wrong , the settings off and a number of other things . The Harley shocks adjusted to your setting absolutely would out perform Ohlins set up wrong , both set up correctly Ohlins would win. Ohlins or other high end shocks are not for everyone , the more adjustments they have the better ride you can get , but also the more that can go wrong if not set up correctly. I've stated many times for most people the basic Ohlins #2 shock is the best choice , you set the sag and ride , nothing else. As people we are all different , some learn through reading , some through verbal communication and some are visual , that's why I always felt if someone made a video of install and adjustments and put it on youtube people would have less problems . Howard is a wealth of knowledge , but with that said he can be too technical when talking to him at times which could confuse some people , the written instructions actually give you more information than you need which could be confusing too. I also think many people make things tougher than they need to be when doing projects . With my Ohlins #3-#3 , #6's and JRi B's I had dialing them in was not that difficult. I set my sag and put the adjusters at the stock recommended setting. I then rode a road by my house that was a rough road , usually I found going 1-4 click in one direction or the other dialed the bike right in for a great ride. Adjusting from there to 2up was nothing more than me going 2 clicks stiffer on the sweep valve. I'm sorry those with problems couldn't get them to work because you are missing out on a great product , but sometimes going back to stock settings and starting over with little adjustments will do wonders . With my #6's setting them up was easy like the #3-#3's with the exception that I found for me they like a little less than the 1/3 stroke sag suggested. Good Luck to all.
Old Apr 6, 2015 | 01:16 PM
SWThomas's Avatar
SWThomas
I went with the Ohlins 2-2B from the same vendor. I set sag and installed the tie-wrap. I had to go an additional 8 turns down on the adjusting collars to get them to where the tie-wrap was not at the bottom bumper after riding. Now it rides like a dream. But I'm 200 pounds and have the black springs.
Being that you had the 3-3 shocks, did you trying playing with the damping wheel to see if that made any difference?
Old Apr 7, 2015 | 06:38 AM
hog95023's Avatar
hog95023
Bagman1 were those 12 inch or 13 on the shocks you took off?
Old Apr 7, 2015 | 07:49 AM
bagman1's Avatar
bagman1
12 inch
Old Apr 7, 2015 | 07:51 AM
grbrown's Avatar
grbrown
Wink
The springs are available in either black or yellow, but in various rates for both colours, they are not colour coded.
I have the #3-3 and after initial set-up, plus a second adjustment for sag a while later, have been very happy with them. I haven't adjusted the damping by much. I seem to be lucky in not finding any need to make frequent adjustments, but I will add that Mrs B is VERY happy with them - they have transformed our bike, especially for her.
Old Apr 7, 2015 | 09:55 AM
SWThomas's Avatar
SWThomas
It seems to me like setting sag is almost not needed. I understand it's an initial setting but putting the tie-wrap on the shaft really told the story on where I needed to adjust the shocks.
