Broke end off spark plug...while still I n the engine
Old Apr 7, 2015 | 08:02 AM
2kids3pets's Avatar
2kids3pets
I just Googled "broken spark plug"
Pretty surprising how common this problem is.
Old Apr 7, 2015 | 08:15 AM
huck 08's Avatar
huck 08
Wow that sucks
Old Apr 7, 2015 | 08:26 AM
Cool Inferno's Avatar
Cool Inferno
Google is your friend. Found this document that may help.
http://www.federalmogulmp.com/en-US/...wist%20Off.pdf
Old Apr 7, 2015 | 08:47 AM
The Cheesehead's Avatar
The Cheesehead
Thanks for all the words of wisdom on this one...and this one is the one with the best promise, I think. I was trying to figure this out but did not want to expand the opening with a round easy out. Duh...square one! Thanks for this link and I'll report back as soon as we have our results later this evening.
This is the one we're going to try...more to come...
Old Apr 7, 2015 | 09:18 AM
hattitude's Avatar
hattitude
Thanks for that link.....
I couldn't picture what the hell happened here until I saw this link. I always thought the hex was part of the threads..... never knew they were separate.
I always use a little anti-seize on aluminum heads, but I will keep this info for future reference
Old Apr 7, 2015 | 10:53 AM
groupw's Avatar
groupw
Originally Posted by 06SGWA
If he doesn't have the sense to not crank down a plug that hard, he has no business using an easy out of any other method of trying to remedy this. Hand it off to someone else.
........ my thoughts exactly
Old Apr 7, 2015 | 10:56 AM
dansflhti's Avatar
dansflhti
This might be over doing it but,if one was concerned about metel getting into the cylinder,couldn't you remove the header,rotate engine until the intake valve is closed and exhaust valve is open,pressurize the exhaust port with air and then anything will just blow out the plug hole.Might be just as east to remove the head....lol.
Old Apr 7, 2015 | 11:11 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Where's the pic's
Old Apr 7, 2015 | 12:45 PM
HardRider1's Avatar
HardRider1
So after reading the link provided one has to ask one self, did he actually over torque the plug in..... or........ did he actually cross thread the plug in the hole? In any regard good luck!
Old Apr 7, 2015 | 12:57 PM
Uncle Larry's Avatar
Uncle Larry
I always thought the hex was part of the threads..... never knew they were separate ... They're not separate but it will break at the area below the hex.
