Question about changing exaust
Old Apr 7, 2015 | 11:57 AM
jkeeton81's Avatar
jkeeton81
Default Question about changing exaust
Hey guys,
So I have been talking to a shop about replacing my current exaust on my street glide. I wanted to do a vance and hine setup, including headers and air cleaner. It has always been my understanding that when doing that, some sort of fuel pack is required to be added. This shop told me that is not the case and that it is optional. Is that correct?
Thanks
Jason
Old Apr 7, 2015 | 12:01 PM
SBates08's Avatar
SBates08
You are correct. When doing both A/C and exhaust a fuel tuner is needed.
2010 Limited with some stuff
Old Apr 7, 2015 | 12:03 PM
IdahoHacker's Avatar
IdahoHacker
Well, as usual, this is a question of semantics.
Do you "have to" add a "fuel pack"? No.
If you do both freer flowing air cleaner AND freer flowing exhaust system, "should you" "retune" the bike? Yes.
If you don't retune the bike, will you get the horsepower and torque increases that you would get if you do retune the bike? No.
Is the cost of the tune, which could include some combination of labor, tuner module, and/or download, and/or dyno time, be worth the additional horsepower and torque increases?
Dunno. Your call.
Old Apr 7, 2015 | 12:04 PM
JMC22's Avatar
JMC22
If you are doing new headers/pipes & Air Cleaner - yes you will need to change the MAP on your bike.
Stock bikes are set to the lean side to get thru emission's, thus when you allow more air in thru an AC, and more exhaust out thru new pipes you get more HP and for that you need to rebalance the air/fuel mixture and put more fuel in.
Fuel Moto - PV2 is the way I went and found it to be a great item.
Old Apr 7, 2015 | 12:14 PM
grbrown's Avatar
grbrown
Jason, as already indicated this is not a simple subject! Your shop may provide a download that will adjust your bike so that it keeps its EPA settings, which a dealer can also do. I personally would be unhappy if they don't. A tuning device can also do that, but more importantly it can adjust your fuelling (and in some cases ignition timing as well) to optimise your engine's performance, using good ole fashioned air/fuel ratios instead of the lean mean EPA ones.
In my case I have a mildly modified EFI bike with a basic tuner (Dobeck), which runs fine, but my carb bike is dyno-tuned and runs like a champ.
Old Apr 7, 2015 | 12:35 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If that is all you ever plan on doing to your bike, a fuel management device would be a wise purchase. That can be accomplished with either a simple dealer download, a set of X-ieds, or a micro- tuner of your choice. If however you plan on doing any engine modifications in the future a fully tunable device of your choice would be the best route to go.
Old Apr 7, 2015 | 12:39 PM
hdgzr's Avatar
hdgzr
If you have the V&H exhaust and intake added, you have a couple of choices if you want to stay with the V&H product line; the FuelPak, which is a piggy-back device to your stock ECM. Or the newer FuelPak3, which will flash your existing ECM with new settings; you also have the ability to auto-tune or change settings as you change equipment to a point. If additional future mods is a possibility, I would probably look at the PV2.
A dyno tune isn't necessary, but if the tuner is worth his salt, he can maximize all your new add-ons to their best potential. If he just installs a canned map, you can do that yourself with an auto-tune on the FP3, or any of the other quality tuners. Good luck.
Old Apr 7, 2015 | 12:43 PM
UUNetBill's Avatar
UUNetBill
Originally Posted by jkeeton81
Hey guys,
Thanks
Jason
I'd think that your shop should at least give you a little more information on what they mean by 'optional' - as others have said, do you HAVE to do it? No. Should you do it? Probably, if you're already spending the $$ on the other pieces, spend a bit more to get the most benefit out of 'em. But I think the shop should take 5 minutes and at least explain the pros and cons of your choices...
Just my $0.02.
Old Apr 7, 2015 | 01:13 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Hey guys,
Thanks
Jason
Hey Jason,
If you are going to be changing the Exhaust and the Air Cleaner then you will need some type of Fuel Management.
Devin and Kevin use the Power Vision and they are 100% satisfied with their's. One of the many good things about the Power Vision is it is delivered to you with a Custom Map, for Your Bike, already installed in it. You can plug it in, load the new tune into your bike, unplug it, and be riding with the New Tune in 5 minutes.
Also, below is a thread on EFI options. Hope this helps you out
https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Apr 7, 2015 | 01:23 PM
0ldhippie's Avatar
0ldhippie
Find a different shop...
