please help,
Old Apr 13, 2015 | 06:13 PM
hdultra2010's Avatar
hdultra2010
Originally Posted by lp
Not sure what to make of your map sensor readings. Note that there are like four wires there. One set is for intake temp and the other for air velocity.
When your twist grip sensor goes out it will throw several very obvious codes centered around the grip sensors themselves and with titles like "sensor correlation error" etc.
It will also show a code for reduced power mode which pretty much means you can't get the bike over 1500 rpm or something. The grip sensor is probably not your problem...
Your bike does not have an IAC and it's weird that it's throwing those codes.
It sounds like you have a problem with your intake/induction module which with the help of the ECM and all the other sensors, does the job of the older style IAC.
To be sure, I'd take it in, but one thing to try right away is to disconnect and reconnect the connector going to the servo on the throttle body.
Corrosion in that connector does all kinds of funny stuff. Easy to check anyway...
i read somewhere that someone has the same thing that happen to me , and since i just put a new handlebar , thought it maybe the issue , ordered another bar , will let u know when i get it and put everything back together and check the conector that goes to servo on the intake, i think you are talking about the throttle control actuator.
thanks for your help.
Old Apr 24, 2015 | 02:41 PM
hdultra2010
Talking
well, my problem is solved after changing the sensor TMAP, didn't help when I took short ride, then today I was planning to tear down the fuel pump and change the fuel filter , got to dealer got new filter and new fuel line, turn out it was the fuel filter hat caused all the problem , I couldn't even believe that it could do that, remind u that I was planning to do fuel filter since I have 23000 miles on bike, and book ask for at least 25000 miles to change , what a relief, I checked every freaking wire according to book , I almost thought It will be the intake manifold, but glad it was just the filter.
I post this just to help anyone that had or may have same symptoms, my advice check fuel filter first ,
I also unplugged the powervision and cable off.
Now am going to ride for few hundered miles then back to se255 cam .
Man it feels good when I ride it with smile on my face for 80 miles lol
thank you everyone for help.
Here is a pic of filter
AlexB_HDMX
May 16, 2017 12:34 PM
Phrogman
Jul 24, 2011 08:38 PM
GodFather
Jun 20, 2009 11:14 PM
strickrodt70
Ironhead
Sep 20, 2008 02:01 AM
rdf24
Exhaust System Topics
Jun 26, 2006 12:42 AM
