Help starter not engaging!
Old Apr 16, 2015 | 09:40 AM
journeyman's Avatar
journeyman
You are describing two different problems.
First the starter did not engage. You replaced it.
Now, it does not disengage.
Sounds like an alignment problem to me.
Old Apr 16, 2015 | 09:41 AM
mrfikser's Avatar
mrfikser
try loosening the bolts that hold the start a half turn or so and then raise the starter a bit, while holding it retighten the bolts..may be enough to give you the play you need..
Old Apr 17, 2015 | 07:26 PM
dlsmith82's Avatar
dlsmith82
Default No start/ spinning problem 1990 FXRS
I was out riding and stopped by the roadside and could not restart the bike. I had a brand new battery (24 hours old). I could hear the starter spinning but no engagement. I assumed it was a bad starter and bought a new one and installed today. No change. I ended up pulling the clutch assembly out so I could remove and inspect the jack shaft and associated parts. I discovered the coupling & retainer ring between the starter shaft and the jack shaft had disappeared (most likely cracked and fell out the back of the bike over the drive belt. An aftermarket rebuild kit is available but nothing from HD. I now have one on order and hope to be up and riding when the weather gets nice next week!
Old Apr 17, 2015 | 07:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I think you need to check how you reassembled the jackshaft and coupling.
Rusty Axle
Shovelhead
Nov 4, 2017 01:39 PM
galtjunk
EVO
21
Dec 5, 2009 08:20 AM
galtjunk
Oct 31, 2009 02:02 PM
thegreenone299
Ironhead
Apr 18, 2009 02:21 PM
