Motor mount ?'s
Old Apr 19, 2015 | 06:40 PM
1HD2NV's Avatar
1HD2NV
Default Motor mount ?'s
With 56k miles on the clock I have developed a helluva shake in the fairing/ bars. I believe most likely motor mount related, and had replaced the handlebar poly bushings 10k ago while in there doing other work. Couple questions:
1) Glide-Pro, stock or other when replacing?
2) Is there a front mount only?
3) Should I be looking at any other cause for a pronounced shake in the front end?
I did do a search but with search words motor, mount, & Glide I came up with a lot of unrelated hits.
Thanks
Old Apr 19, 2015 | 07:02 PM
skydude426's Avatar
skydude426
Glide Pro makes a good front motor mount. I installed the Glide Pro swing arm bushings and motor mount on my wife's 2006 Ultra. We're happy with it.
Old Apr 19, 2015 | 07:51 PM
dawg's Avatar
dawg
Didja check the fairing brackets yet?
Old Apr 19, 2015 | 07:57 PM
Guntoter's Avatar
Guntoter
Take a look at the wheel bearings also. The '10's had some problems with them.
Old Apr 19, 2015 | 08:08 PM
Sc0-'s Avatar
Sc0-
With that many miles, toss in another set of OEM bushings...
Old Apr 20, 2015 | 07:11 AM
hd_rolling's Avatar
hd_rolling
Make sure your exhaust is tightly secured, My D&D muffler came loose at the saddlebag support and it let the engine move all over the place.
Old Apr 20, 2015 | 01:57 PM
1HD2NV's Avatar
1HD2NV
Thanks for all of the suggestions guys. I reviewed fairing brackets last Fall but plan to again tonight. Will also look along frame, exhaust, etc for anything out of the ordinary. The more I look into this it seems less likely with the 09+ mounts vs older style. Front wheel bearings are not original but still probably have 30k+ mi on them. Plan to replace when new front tire is needed.
bxhammer
Mar 4, 2016 07:39 AM
Ugly Troll
May 31, 2012 03:46 PM
Ugly Troll
May 15, 2012 04:41 PM
riden2low
Mar 9, 2012 07:35 PM
steveh326
Sep 12, 2011 10:32 AM
