help with motor mount!
Old May 30, 2012 | 05:55 PM
Ugly Troll's Avatar
Ugly Troll
Default help with motor mount!
Recently, I posted about replacing my front lower motor mount on my 05 FLHTCI. I got a few responses; but today I got what I'd call a DEFINITIVE explanation. I described the problem since the new mount as being excessive vibration, a "tightness" that I felt was not right. Some folks suggested "new and tight" was a good thing! Let me assure you, this is NOT the case in this particular situation. What I found out today, from a reliable indy, was that the new motor mount I was sold (by an HD dealer!) is a high performance part....supposed to "last longer" or some such crap. This guy is in Florida, and my brother has used him for many years...he said the guy knew exactly what the problem was from his description, and even described the new mount to him. He said the solution is to go to another dealer and ask for a stock mount. I wanted to put this out here in hopes of saving someone else the aggravation! Among other problems this has caused me, aside from making my riding unpleasant, is the fact that the excessive vibration has ruined my Zumo 550....I suspect there are also problems inside the fairing with broken stuff as well....haven't got in there yet! Anyway, hope this helps somebody down the line.
Old May 31, 2012 | 02:57 PM
CURTYS06FLHX's Avatar
CURTYS06FLHX
After i changed mine i broke both fairing brackets, and have a bad vibration in the floorboards. Going to Glide pro motor mount.
Old May 31, 2012 | 03:25 PM
stevefxdi's Avatar
stevefxdi
i had a glide pro mount on my 2006 roadking and it only last about 14,000 miles before tearing
Old May 31, 2012 | 03:46 PM
hangin iron's Avatar
hangin iron
Default motor mount fix
over in the evo section i put up some pics of the fix i did to my mount it will never break again. i welded washers to the bushing i have no problems with it.
Big Dave
EVO
May 5, 2015 06:37 PM
1HD2NV
Apr 20, 2015 01:57 PM
gliderman
Sep 25, 2009 04:24 PM
gliderman
Sep 20, 2006 07:35 PM
turbo54
Jul 27, 2006 02:40 PM
