Audio Knob Replace ?
Old Apr 24, 2015 | 01:00 PM
acchd's Avatar
acchd
Default Audio **** Replace ?
Anybody know purpose of the small piece metal pictured to right of **** that came packaged with ****. My '09 Service manual doesn't mention it in replacing.
Old Apr 24, 2015 | 01:38 PM
SBates08's Avatar
SBates08
No idea. The chrome replacements don't have that piece either.
2010 Limited with some stuff
Old Apr 24, 2015 | 01:43 PM
MCSarge's Avatar
MCSarge
looks like a shim of some kind. Maybe if the stud is worn this will provide added friction to keep it in place.
Old Apr 24, 2015 | 01:54 PM
acchd's Avatar
acchd
Ehh bet that is it Sarge. It will fit in slot of **** just figured it'd be mentioned in Service Manual. Maybe it was some type of addendum to part later.
Old Apr 24, 2015 | 02:46 PM
Weavr99FLHT's Avatar
Weavr99FLHT
It is a spring clip - prevents the **** from being too loose
Old Apr 25, 2015 | 09:43 AM
Veekness's Avatar
Veekness
It fits into the slot made for it in the ****. Helps prevent the **** from being loose, just as Weavr99FLHT said...replaced mine last week...fiddled with it a bit and sussed it out...
Old Apr 26, 2015 | 09:52 AM
z71_fourwheelin's Avatar
z71_fourwheelin
Thinking mine needs to be replaced as well. How easy is it?
Old Apr 26, 2015 | 03:15 PM
acchd's Avatar
acchd
It's pretty easy put one on today. The switch shaft is like a half moon shape with knobby rough side & flat side. I inserted the small metal shim inside new **** and pressed it on pretty hard. To know if you're pressed it on far enough you'll have about 3/16" between main switch housing and audio ****.
Old Apr 26, 2015 | 06:46 PM
z71_fourwheelin
Thanks
Old Apr 27, 2015 | 07:49 AM
Veekness's Avatar
Veekness
If you have cruise control, just make certain you get the **** that is for that...it is a different **** than non-cruise models. The model number for cruise-equipped is 71822-98...the larger one for non-cruise is the one the OP pictured...I thought it was 71823-98, but the pic shows a different part number. Very inexpensive, $8.12.
