New wheel, abs light. help
Old Apr 29, 2015 | 07:19 PM
Frank Dukes's Avatar
Frank Dukes
cleared codes and ran around a city block all times after install.. just finished old wheel install, test ride up now.
Old Apr 29, 2015 | 07:28 PM
Frank Dukes
****. works fine with old wheel. what a pain.
Old Apr 29, 2015 | 09:47 PM
pjones1969's Avatar
pjones1969
When I had my wheels swapped my new bearings were installed backwards, ABS light stayed on, Indy installed NEW bearings at his expense, ABS light went off, sounds like you have the same problem
Old Apr 30, 2015 | 08:29 AM
Frank Dukes
Most likely. Problem being i internet ordered the wheel.. and i have a ride planned this weekend and want the new wheel on.. meaning likely 100 bucks out of my pocket for new bearings pressed. thats IF my local stealer stocks the OEM bearings i want to put in it instead of these aftermarket cheapies.
Old Apr 30, 2015 | 09:42 AM
Frank Dukes
welp, 50 bucks for OEM bearings, in stock. 40 buck labor quote from both my indy and Kegels HD. surprising, but dealer wins this round i guess.
Old Apr 30, 2015 | 09:43 AM
p51bombay's Avatar
p51bombay
So go on your ride and address the problem later, it won't hurt anything other than the light will remain on and ABS will be inactive.
Take a photo of the wheel - either it has non ABS bearings on both sides or the ABS bearing is installed backwards - if the latter, you only need to pull one bearing. If you take the wheel in, you shouldn't be charged more than .5 hours labor plus a new bearing. Or invest in a bearing puller/installer - they don't cost that much and really pay for themselves the first time you install a set of wheel bearings.
Old Apr 30, 2015 | 10:54 AM
Frank Dukes
Vendor made it right with me. Credited me the cost of the bearing replacement on my backordered rotors and threw in a t shirt for my troubles. other than the hassle, Southern Motorcycle Works did what they could to do right by me and were very hospitable on the phone. Good on them for sure. The wheel it self is gorgeous, these things happen i guess. I'll just be happy when its on and done.
Old Apr 30, 2015 | 12:20 PM
p51bombay's Avatar
p51bombay
out of curiosity, what brand/style wheels were these and was this one of those pre-mounted packages where the wheels/tires come already assembled?
Old Apr 30, 2015 | 12:38 PM
Frank Dukes
correct sir. Southern Motorcycle Works Legend 21" wheel. they sell on ebay as well as their personal website www.southern-mc.com heres a pic of it on my bike.
beyond the initial issue they went above their responsibility to make it right and wanted to make me happy however i was most comfortable whether that was shipping the wheel back, shipping me a new bearing or giving me the discount on my rotor order. I chose the latter.
I am happy with both their customer service and the product. things happen. I was initially a little frustrated but the owner and his wife are the customer service dept and they did everything they could to please me.
Old Apr 30, 2015 | 12:47 PM
p51bombay's Avatar
p51bombay
ah ok - I wondered if those where PM's that one distributor offers as pre assembled/mounted sets but those are their wheels assembled in house - I guess anyone can make a mistake. Did the bearing reinstallation correct your issue?
