tools needed for inner primary work
Old May 4, 2015 | 12:11 AM
bigheadted's Avatar
bigheadted
Default tools needed for inner primary work
Hello, what actual specialty tools are needed for removing the inner primary to replace IPB, seals and shift shaft seals?? Developed a small leak at IPB are and figure to tear it down, replace IPB and related seals.
Reading the manual it looks like a heap but but I know some of you have done it with minimal specialty tools.
Bike is a 2004
Old May 4, 2015 | 11:10 AM
98fat's Avatar
98fat
Default just did mine
I just did all my seals on the inner primary on my 2006 Street Glide. If you are interested in pulling the race I would sell you the tool pretty cheap. My race had walked up the shaft and I had to grind it off so the tool never even got used. I would strongly recommend you replace with a one piece bearing ( I used the Jims). Ironically my worst leak was around the stator plug.
Old May 4, 2015 | 11:12 AM
98fat's Avatar
98fat
Sorry to answer the question, the only other specialty tool is a good set (inch and foot) torque wrenches and a service manual.
Old May 4, 2015 | 11:34 AM
skydude426's Avatar
skydude426
A primary locking tool is very handy.
Old May 4, 2015 | 05:18 PM
bigheadted's Avatar
bigheadted
I do have the tq wrenches covered and any other hand tools.
I do need a 1/2 air impact for the comp nut right ?
What about a puller for the clutch ??
How much you asking for the puller 98fat??
Old May 4, 2015 | 06:49 PM
skydude426's Avatar
skydude426
A beaker bar and a pipe extension will get the comp nut loose but you'll need a primary locking tool.
Old May 4, 2015 | 06:53 PM
twistedcherokee's Avatar
twistedcherokee
Nice thing about the 1/2" impact is it will normally take the nut off both the comp & the front sprocket with out the use of the locking tools.
Toby
Old May 4, 2015 | 06:55 PM
skydude426's Avatar
skydude426
I've bought several tools here. Good quality and fast priority mail shipping.
http://www.georges-garage.com/index.html
Old May 4, 2015 | 07:14 PM
Guntoter's Avatar
Guntoter
Georges Garage has the tool needed to remove and install the inner primary bearing and seal, costs a little under $100. That and the bearing race remover and installer and primary drive locking bar are pretty much the special tools you need. You can use an impact to remove the compensator and clutch nuts if you don't want to use the locking bar, remember the clutch one has reverse threads, or it should. Be prepared for certain members to start freaking out when you mention "impact" as they will holler that the stator will self destruct when using an impact. It won't but they will tell you it will. Check the service manual to be sure on the clutch nut thread, I know '07 and up are reverse threaded. The whole clutch and compensator assembly with chain will come off as a unit. A set of long shank allen ball end sockets will help with the starter bolts. Take a look at your set up to make sure they are allen, again they are on '07 and up.
If your shifter shaft seal is not leaking and is perfectly dry, I would not mess with it.
Old May 5, 2015 | 10:01 AM
bigheadted's Avatar
bigheadted
Thanks members for the great info !!
