Decel POP
Old Apr 25, 2007 | 03:14 PM
Bill918's Avatar
Bill918
Default Decel POP
I have a stage one and V&H dual ovals on my 05' RK. I recently put on V&H dresser duals (true duals). I am now experiencing a significant amount of decel pop. I have already checked to eliminate air leaks as a cause. Is this normal with this setup or am I running lean and in need of a dyno tune? I am currently using a SERT. Any help would be appreciatied.
Thanks
Old Apr 25, 2007 | 03:17 PM
Silverearl's Avatar
Silverearl
Default RE: Decel POP
My 06 with the total V&H setup pops. It is something that I have just accepted and sometimes have enjoyed. Specially when someone is behind me..
Old Apr 25, 2007 | 05:26 PM
gunrunner's Avatar
gunrunner
Decell popping is the result of a lean condition retune is needed.
Old Apr 25, 2007 | 05:39 PM
Kahuna's Avatar
Kahuna
Like what gunrunner said! It's not good for the engine and it will get worse as time goes on! Lean condition makes the engine run hotter and beat up your valves!
ORIGINAL: gunrunner
Old Apr 25, 2007 | 07:57 PM
Blueslover's Avatar
Blueslover
You are running lean....run, don't walk to the nearest tuner, or find the MAP on your SERT that more closely resembes TD's and SE A/C and load it into the ECM.
Old Apr 25, 2007 | 08:03 PM
Taterdog's Avatar
Taterdog
Everyone's right -- you're running lean, but what octane gas are you running too? I mistakenly put 87 octane in mine once and, whoa nelly, sounded like the fourth of July on decel. Once I reloaded with higher octane gas, most of it went away.
Old Apr 25, 2007 | 10:55 PM
rustyrun's Avatar
rustyrun
My 2002 FLHTCpops on decel as well noticeable more with Sunoco premium. However, it spits and pukes less on take off with this gas. This would indicate a lean mixture as well but the plugs are always black and I have to clean them after every few rides. Bike gets like 35mpg on highway at 70mph and I ride it easy. I have never been able to figure this out over the past 1.5 years and moco mechanics state jet and mixture is correct.
Old Apr 25, 2007 | 11:11 PM
scottt's Avatar
scottt
I have a 07 SE Ultra. SE Pipes, air cleaner, and SERT. Two dealers have dyno'd, still the bike has decel pop. Both dealers HD dealers spend close to 5 hours on the dyno. The bike runs great. Going to keep working on it, but I don't have much hope for a solution. IT does not seem to run hot, it does not ping, it pulls hard.
Good luck
Scott
Old Apr 25, 2007 | 11:36 PM
fatstreetglide's Avatar
fatstreetglide
ThunderMax Autotune will make a huge difference in the way your bike will run. No decel popping. Stong and smooth acceleration that feels like it should have from the start. Expensive but well worth it IMHO.
Old Apr 25, 2007 | 11:49 PM
Retired_Ted's Avatar
Retired_Ted
You need to tell your tuner to enrichen the 0% throttle position slightly - most of the time, that will practically eliminate the decel pop.
