Driving myself nuts about oil....
Old May 4, 2015 | 07:02 PM
overthehill?'s Avatar
overthehill?
Thanks for the replies....what I did find out was that there are lots and lots of combinations that work...yikes.
The issue of having warranty problems is what is actually driving this....clearly, you don't need to have the work done at the dealer...but, and a big but, if you have a problem down the road (no pun) not having the 1k done at the dealer could 'complicate' things....or so I am told.
Old May 4, 2015 | 07:10 PM
SafetyMan's Avatar
SafetyMan
20w50 VTwin oil in the engine
PRIMARY oil in the primary
Gear oil in the gear box
Amsoil or Mobil1 are both excellent choices for the engine
HD F+, or any PRIMARY specific fluid, I really like Red Line Syn Primary fluid for the primary
Amsoil SevereGear 75w-110 or 75w-140, or Red Line with Shock Proof are among the best for the trans.
There are literally a thousand combinations, do some reading here, and come up with your own 1,001st.
Old May 4, 2015 | 07:14 PM
mike5511's Avatar
mike5511
Last time mine was at the dealer was for the 1000 mile service. I took them RedLine products for all three. I'm positive they poured at least the tranny fluid in!
This should drive you COMPLETELY over the edge.....
http://harleytechtalk.org/htt/index....c,75005.0.html
Old May 4, 2015 | 07:15 PM
lh4x4's Avatar
lh4x4
When it gets right down to it as long as the correct API rated MC oil is used it matters not if mineral oil or syn, All oils are now engineered and have reached their maximum capability.
The only next step that engineers can think of is to start the rotation on oil then air inject to float the crank on a thin cushion of air.
With all factors of use, care and miles the same the TC will last as long on syn, mineral oil of any brand of the proper spec'd oil.
With that in mind I choose the $3.98/qt. of Valvoline 20-50 MC oil for all my engines from the EVO's to the 120R. 30K miles a year between them for year after year and absolutely no issue. I do all the services myself and save a small fortune as I average 6 services per year. I come in at under $40 per service. You all know what 6 services would cost at the dealer.
This is my garage where all the work is done.
I document all the services done on under warranty bikes/vhehicles with pictures of the service manual, tools, oil and also do a log of each item to be checked on the particular service and what the findings were.
I would defy any attempt not to cover a warranty claim do to the dealer not doing the service.
Old May 4, 2015 | 07:16 PM
Brewmany's Avatar
Brewmany
There is nothing magical or special about the first service, (or any other for that matter) not sure why some think so. Do it yourself, have an indy do it, or have the dealer do it, makes absolutely no difference in regards to warranty.
Old May 4, 2015 | 07:25 PM
Norms 427's Avatar
Norms 427
All you need to know about oil:
Oil in (primary, tranny, engine) case = good.
No oil in (primary, tranny, engine) case = bad.
Old May 4, 2015 | 08:18 PM
SafetyMan's Avatar
SafetyMan
As a re-direct, please do not use mineral oil....
Use standard oil derived from crude and hydrocarbons, if you so choose... but not mineral.
Old May 4, 2015 | 09:37 PM
Ron750's Avatar
Ron750
Default Driving myself nuts about oil....
I drove myself nuts, too. Tried Syn 3, Dino oil, Mobil One 20-50. Just had Lower gasket leak fixed. I think there of lots of good oils, but I don't think it is good to switch back and forth. So I am just going to stick with Syn 3. Picked up my bike yesterday, ran great, shifted great.
Old May 4, 2015 | 09:49 PM
overthehill?
Good stuff, thanks, but let me, if I may throw another variable at ya....noise.
I am told that some oils cause excessive top end noise and some reduce it...same for trans.....true?
Old May 4, 2015 | 10:02 PM
bklynbob's Avatar
bklynbob
Originally Posted by dawg
You mean tranny and not primary for the severe gear, yes? That combo will work
Great choice....
