puzzled in ohio
Old May 7, 2015 | 09:18 AM
colwell's Avatar
colwell
6th Gear
Default puzzled in ohio
Left the house Monday and got 1/4 mile and tachometer went out and the bike started missing and backfiring made it home then was hard to start....2001 Electra Glide Classic carb model....any help would be great
Old May 7, 2015 | 10:12 AM
hdultra2010's Avatar
hdultra2010
Check the wiring . U may have a short somewhere . Chwck the battery bolts uf tight. And ground to frame is good .
Old May 7, 2015 | 10:25 AM
grbrown's Avatar
grbrown
If the above doesn't solve it recharge your battery, then try starting your bike again. If that works, don't assume all is fine, check battery condition (many auto parts stores can do that) and replace if necessary. Go to the Tech Electrical section where you will find two Stickies on checking your charging system, which should identify any underlying problems. Let us know what you find.
Old May 7, 2015 | 12:26 PM
colwell's Avatar
colwell
6th Gear
Battery good....New wrinkle today I pulled the plugs had no spark....turned around to get the new plugs ....plugs started lightly firing and I was five feet away and the ignition was the only thing on.....?????
Old May 7, 2015 | 02:08 PM
batman.'s Avatar
batman.
Well two things, First any of us from Michigan all wonder why anybody would want to live there thats strange enough... Just playing...
Now on to the real...Ive gotten bad gas from two different gas stations on two different trips on my old bike. Did you just fill up recently at all?
Batman
Old May 7, 2015 | 02:12 PM
SafetyMan's Avatar
SafetyMan
I second that.
Old May 7, 2015 | 02:48 PM
fwb35's Avatar
fwb35
Having been to both places and being from Virginia, why would anyone want to live in either of those places lol
Old May 7, 2015 | 03:04 PM
SafetyMan's Avatar
SafetyMan
If you've never been to Northern Michigan, you wouldn't understand...
I was born and raised in Michigan, moved to Virginia, and now live in Texas, if that tells you anything.....
Old May 7, 2015 | 03:11 PM
Magnut1's Avatar
Magnut1
possible shorted coil.
Old May 7, 2015 | 03:25 PM
fwb35's Avatar
fwb35
Your right, why anyone would want to live where it is winter 8 months out of the year........ Or be surrounded by yankees.... lol
