All Problem Solvers Welcome!!!
Old May 9, 2015 | 01:42 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by skydude426
If you want to look at apples to apples, Fuel Moto lists a Power Vision with auto tune for $779 and a Thunder Max for $849. I guess the PV isn't half the price. The PV piggy backs the stock ECM and the T-Max replaces it. I prefer the cleaner install of the T-Max. Either way is a good option.
Negative, sir.
The Power Vision does not piggyback.
Fuel Moto sells the Power Vision with auto tune for $499.
You CAN purchase the wide band pro tune kit for it, but not necessary, unless you're going way wild with the engine.
My PV2 (Same as PV, with connections for a '14+ Touring bike) is a flash tuner, and I have run many auto tune runs with it.
PowerVision, FP3, TTS and the SE(PST)(SPT) are flash tuners.
You plug them in, gather data, build maps, load data, and can take them off and put them in a drawer.
And if you want those apples sliced, you can buy the SAME PV2 for $429, but without the excellent support and accessories provided by FM...
...and about HALF the $849 you quoted for the Tmax.
"Piggyback" units have to stay with the bike, and do not program or tune the ECM.
Examples:
FuelPak adjusts AFR in open and closed loop, but does not automatically adjust the timing. You have to call for a list of codes based on your mods.
Cobra Fi2000: Works off Continuously Variable Tuning, reads the pulses and pulse length form the injectors, makes adjustments, and does not run a constant AFR. It does not have a set "tune" but rather is a constant read and adjust type fuel management unit.
The PCV tuners can be used with a canned map, or can be adjusted with a laptop or can by dyno tuned. They override the Harley-Davidson tune.
Old May 9, 2015 | 01:45 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by p51bombay
Power Vision doesn't piggyback, its a flash tuner.......it CAN be left on but doesn't need to be.
Aww, come on man... he's mad at me, no reason to get him mad at you too...
Old May 9, 2015 | 04:02 PM
Weavr99FLHT's Avatar
Weavr99FLHT
$779??? $499 last I checked....
Old May 9, 2015 | 04:44 PM
ravens9322's Avatar
ravens9322
well i have been doing a ton of research and think i have made my decision. I went to the harley dealer today and they obviously wanted me to get a race tuner and have them dyno the bike for a whopping $800. Thats pretty far out of the allowance the wife has set (cam chain tensioner check in 2 weeks) fingers crossed.
So i am pretty set on taking the old cobra fi2000 out and putting in the vance and hines fuelpak. I realize it doesnt have all of the great functions that a lot of the other units have. But, i only have a high flow filter, true duels and slip ons. I dont plan on going more than that anytime soon so i dont think i will need more than the fuelpak delivers.
Old May 9, 2015 | 05:12 PM
p51bombay's Avatar
p51bombay
If that happens YOU are buying the popcorn - extra butter please.
Old May 9, 2015 | 05:15 PM
SafetyMan's Avatar
SafetyMan
If you've already got the Cobra unit, why change?
I honestly don't think it's worth the money to go to another piggyback unit.
I don't LIKE the Cobra, but I do not believe there is enough improvement to justify going to a FuelPak.
My 2 cents, of course.
The good news, more money now, or save for a flash tuner down the road. I do not recommend SE tuners, but any of the others, including a Tmax will be a great improvement.
Old May 9, 2015 | 06:34 PM
hattitude's Avatar
hattitude
Originally Posted by heritageblue2013
You had moisture and it dried out?
That would be my guess.....
Check and clean electrical connections... and don't forget to reattach with dielectric grease on the connections.
As far as tuners, I am biased with a PowerVision from Fuelmoto.
I get all sorts of map assistance from both Fuelmoto AND Dynojet. I have used both as sources for base maps.
A few basic auto tune sessions (on '07 & later bikes) and the tune is dialed in. On a tune for my '03 (without O2 sensors) they gave me a tune that was spot on, without the need for a basic auto tune session. I'm sure if I had problems, they would have tweaked it for me.
Good luck with your decision.....
Old May 9, 2015 | 08:16 PM
vickers1's Avatar
vickers1
I really think the first thing you should do is check for codes.
Old May 9, 2015 | 08:54 PM
ravens9322's Avatar
ravens9322
I'm pretty sure the cobra is broken so that's why I want it replaced.
Also, an update, I took the wife for a 20 minute ride today and the bike didn't die or run like complete ****, but it wasn't running as good as weeks ago. I got a few loud bangs and back fires on deceleration. The bike didn't have 100% of the power and it just felt like it wasn't tuned at all.
That's why I'm searching for a new tuner.
Old May 9, 2015 | 09:13 PM
skydude426's Avatar
skydude426
Sounds like the OP has decided the route he wants to take. I'm not mad at anyone. Just adding my input into this thread. The Power Vision is a great product. I never said otherwise. The auto tune pro uses a piggy back control module in order to use wide band O2 sensors like a T-Max. The only way to get real time feed back is from a wide band O2 sensor. The price for a Power Vision with auto tune pro on FM web site is $779.
