Batwing fix help?
Old May 11, 2015 | 06:05 PM
RidemyEVO's Avatar
RidemyEVO
Default Batwing fix help?
Always seems to be something on the old bike that needs updating to something better.
While wiping down the front end I noticed the headlite was leaning outward a bit, took headlite off and found that most of the holes for holding the back pot are history. I have a couple ideas for fixing it but would like to hear from you guys. And please don't say new batwing.
Old May 11, 2015 | 06:33 PM
dawg's Avatar
dawg
Can you have a metal ring fabbed with holes and attach it to the fairing then use that to attach the bucket to.
Old May 11, 2015 | 06:36 PM
RidemyEVO's Avatar
RidemyEVO
I have thought of that but you just gave me a different idea, maybe better with two rings, one in behind and one in front. I guess the pot doesn`t have to be right up against the original base right
Old May 11, 2015 | 06:52 PM
Ride my Seesaw's Avatar
Ride my Seesaw
Buy a used old batwing then? Just kidding. Go to the hobby store and buy some brass sheets. With tin snips and some folding and hand forming you could fabricate your own collar or ring. Just drill holes in the appropriate places for your headlight assembly to remount. That, or some soft copper tubing that you split a seam on. Place the seam over your damaged innards and form the tube around its circumference. Flatten the tube to grip the circumference with pliers or a wood block and hammer, re-drill holes where needed.
Old May 11, 2015 | 08:32 PM
stro1965's Avatar
stro1965
I'd just try to use some washers and JBWeld to rebuild the holes.
Old May 11, 2015 | 08:45 PM
Ride my Seesaw
Or the old standby, wire mesh and Bondo.
Old May 11, 2015 | 10:47 PM
Bill03E's Avatar
Bill03E
Go buy a can of fiber glass resin jelly , cover all of the holes with it, sand/grind it flat , drill your holes again , and you are done, maybe shoot some rattle can black on the worked area.
If you do this, resin jelly is really hard to sand by hand, so don't put a big lump on , and you will need to sand all of the paint with 36 grit paper that you are going to spread jelly on. It works just like body filler add hardener mix then apply.
If you have a grinder with a sand disk that would work much faster.
Old May 12, 2015 | 02:21 AM
tfi racing's Avatar
tfi racing
Who's the savage that dared to use Robertson screws on a vehicle? Unless it was a life and death emergency,he should hang his head in shame...
Old May 12, 2015 | 02:59 AM
Ride my Seesaw
What's wrong with Robertson's? It was invented as a no-slip screwdriver in which the screw could be held horizontally using only one hand without falling off, something other screwdrivers can't claim. The Fisher Body company which made the car bodies for the Ford Motor Co was one of Robertson's first customers. They used over 700 Robertson screws in the Model T, this was because Henry Ford realized that the Robertson screw saved around 2 hours of labor for each car. Ford tried to get the exclusive license to use and manufacture this product but Robertson said no. Henry F. Phillips of the Phillips screwdriver fame had no such compunction and let Ford have his way with it.
Old May 12, 2015 | 05:25 AM
RidemyEVO's Avatar
RidemyEVO
Good input but doesn't sound permanent and solid enough.
