Limp Mode
Old May 11, 2015 | 06:40 PM
Sandcrab's Avatar
Sandcrab
Default Limp Mode
Took off Wednesday to ride down to Cherokee NC to ride the dragon and the Cherohala Skyway. About 50 miles from home, bike went into limp mode. Could not go faster than about 5 mph. Stopped at a gas station and called the closest dealer to come get me. They said they would check to see when they could come and call me back. While waiting, decided to try it again. Everything worked fine so called the dealer and told them I was on my way to them and if I broke down again, would call them. When I got to the dealer, they said they applied dielectric grease to TCA connectors. I drove another 1400 miles and never had a problem. So what is the TCA connector, and where is it? I am going on an 8K mile trip in a month, and don't want any problems like this to happen again. Should I replace something to ensure my mental stability??
Old May 11, 2015 | 06:50 PM
Danny D's Avatar
Danny D
I don't know what a TCA is but I had the same thing happen to my 2013 FLHX TWICE!
I was under warranty and the dealer fixed it and told me the wiring leading to my Fuel Injection had shorted out. They rewired it and its running fine.
As I mentioned this has happened twice and after the bike sits for a while it will start up and run good for a while. If this ever happens again look under your football air cleaner cover and try to find any bared wiring.
Hope this helps.
Old May 11, 2015 | 06:53 PM
GeneseeGap's Avatar
GeneseeGap
Hey there...I had the same thing and think its pretty common.
I had a 09 Ultra Classic (great bike and nice memories!) and the only issue I had with the machine was bad gas and right after it was cleaned out my TCA connector went out. The pins were not connecting right and it would go into limp mode or die if I was making a turn.
Think its called the Throttle Connector Assembly but not too sure and if I remember right it was under the seat. I also remember being told this part can go bad and cause problems such as what we are talking about.
I know someone will come along soon and have a good answer.
All I can say is that I had 38k on the bike and never had another issue.
Old May 11, 2015 | 06:55 PM
Weavr99FLHT's Avatar
Weavr99FLHT
TCA Throttle Control Actuator. Behind air cleaner at roughly 8-9 o'clock position. Known problem with the pins fretting due to vibration and corroding. Unplug, clean and put dielectric grease is usual fix for near term. Most end up replacing the pins or entire assembly. Bike should have thrown a code(s).
Old May 11, 2015 | 07:35 PM
Keithhu's Avatar
Keithhu
I wouldnt over do it on the dielectric grease. I dont personally have experience with this problem, but I recall a post from someone expaining how he had over done it and caused more problems.
Old May 11, 2015 | 08:25 PM
Geezr Glidr's Avatar
Geezr Glidr
My 09 Classic started doing that at 15K miles. Pull over, shut it down, wait 10 seconds, fire it back up, and it could be fine for 2 weeks or it might do it again in 2 minutes. Turned out to be corrosion at the end of a wiring harness under the fairing. Got it replaced & it never did it again. At least you know you can shut down & it'll be OK when you fire it back up. Kinda made me nervous when I was in the passing lane though, wondering when it would do it again.
Old May 11, 2015 | 08:32 PM
hdultra2010's Avatar
hdultra2010
tca is the plug behind the air filter, I believe it is deutsh plug ,with 4 wires.
Old May 11, 2015 | 08:46 PM
SafetyMan's Avatar
SafetyMan
I was getting aggravated reading this thread, until I read this one.
You are dead on, sir.
Why do folks put up "information" if they don't have a clue?
Old May 11, 2015 | 10:51 PM
dcraddo's Avatar
dcraddo
Had this happen on my 2013 Ultra Limited Anniversary. Once I got the bike back to the dealer, they replaced the connector and extended the harness. Had no problems but ended up trading it in on a 2015 CVO Limited.
Old May 12, 2015 | 08:16 AM
Vernal's Avatar
Vernal
Here is another good reason to buy a Service Manual.
There is a table in the back with Acronyms and Abbreviations. In the table you see TCA = Throttle Control Actuator, go to the index and it tells you page 4-22. On page 4-22 you see TCA is the Black plastic box on the left front side induction module, (what the air cleaner bolts to). It has the large connector and wire that lots of folks try to hide behind after market covers. Take a look at it and figure out how to disconnect it in case you ever have this problem.
A service manual will help you get more familiar with your bike and this is always a good thing.
Good luck
