Make sure the fuel tank connectors are making good contact. Next, locate the system relay, in the efi fuse block, under the right side frame cover. Pull the relay and clean the contacts, then replace the relay.
Possible problem areas are improper connection at the fuel tank multilock connector, or bad system relay. If your fuel pump is running with the system relay pulled from the circuit, the relay is likely bad.
