Help
Old May 13, 2015 | 07:55 PM
Drtumolo's Avatar
Drtumolo
Default Help
Last fall I installed new tires on my 07 flhrs. I didnt ride it since because of a health issue but now I am ready to ride again. The problem is the bike is now extremly hard to back out of my garage in the morning. Once I ride it a little it backs like it use to until it sits and cools back down. I have tried it in neutral, clutch in or out, checked and cleaned brake pistons to eliminate brake drag, checked belt tension. Everything seems ok. Please tell me what I am overlooking. Maybe wheel bearings? The bearings are smooth so I doubt it but just dont know.
Old May 13, 2015 | 10:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
It's the oil on the clutch pack discs that's giving you fits. Try starting the bike and pull in the clutch then give it a couple blips of the throttle to loosen the discs up, then try backing it out.
Old May 14, 2015 | 05:53 AM
Drtumolo's Avatar
Drtumolo
Would the oil on the clutch make a difference when the transmission is in neutral?
Old May 14, 2015 | 07:31 AM
batman.'s Avatar
batman.
Check your tires air pressure. My back tire over the winter went down to 20 psi. Had a hard time rolling it backwards at first then did the previous ride check over and found it.
Batman
Old May 14, 2015 | 07:48 AM
OldEnuf2NoBtr
Yep. It sure will. try it next time.
Mike3521
Apr 6, 2016 01:14 PM
Ployd4
Sep 14, 2014 07:05 AM
gearhead harley
EVO
Aug 2, 2011 03:59 AM
Bamm Bamm
Jun 15, 2010 12:27 AM
dhholder
Aug 5, 2009 09:22 PM
