My Engine Build 102hp 113tq
Old May 22, 2015 | 12:03 AM
bagman1's Avatar
bagman1
I did a similiar stage 4 on my 103 that Bob dynoed at 124/121. I did it from the crank up though with a Timkin balanced crank
Old May 22, 2015 | 01:12 AM
trackadaptor's Avatar
trackadaptor
Wink
RC Cycles in Hayward Ca.... No Pinging !
Man o Man Love the TTS Master Tune... Vickie at TTS and Bob at RC Cycles did a great job working with me....
Originally Posted by 0ldhippie
That is really good for 255s. Hope ya got a good tune for guard against pinging.
Old May 22, 2015 | 01:30 AM
trackadaptor
Wink
stayed stock, but had the crank welded ( means 4 points Spot welded / balanced RE Engineering San Jose Ca, )
Old May 22, 2015 | 04:38 AM
Keithhu's Avatar
Keithhu
Originally Posted by Softy 103
Here it is.
As I suspected. STD Smoothing - shave about 5% off that number to get more compareable results. SAE is a better correction factor and it yeilds more accurate and compareable results due to temperature and humidity differences.
http://www.cvoharley.com/smf/index.php?topic=59556.0
Old May 22, 2015 | 05:28 AM
sporacer's Avatar
sporacer
Originally Posted by trackadaptor
Started life as a 2009 FLHTCU 96" 75hp 85tq
After 69,000 miles it was time for new:
As Pictured: 103ci 102hp 113tq - Look at the curve
GREAT for a all around tourining high milage bike Cheaper than a Stage 4 kit
I maintained the Stock Throttle Boddy , and Injectors - read way to many folks not to happy with thier Satge 4 kits
This is the Meat of my changes: Clutch Spring was changed to the SE, Push Rods etc............
Screamin' Eagle Pro CNC Ported Factory Heads with Valve Upgrade
16500013A
BIG BORE PISTON KIT
22144-08B
SE255 Cams
FLH757 Bassani 2into1
Screamin' Eagle Ventilator Performance Air Cleaner Kit-29915-09
Screamin' Eagle Billet Cam Support Plate with High Volume Oil Pump-25282-11
Automatic Compression Release-28861-07A
Part Number 28861-07A
I have seen these results with just a set of pistons and cams. It looks like your missing about 10/10 and id bet the se255's are holding it back.
Old May 22, 2015 | 06:43 AM
Softy 103's Avatar
Softy 103
ok so go a head and subtract 5% still putting out upper teens in Tq. and mid teens in hp. Oh by the way it loves to embarrass 110s.
Old May 22, 2015 | 06:49 AM
Keithhu's Avatar
Keithhu
Yep, great numbers indeed.
Old May 22, 2015 | 07:32 AM
trackadaptor
Default Numbers
SAE Numbers 102hp 113tq Vs 115hp 112tq
Looks like were pretty darn close Bob did say the SAE 5 is true numbers
I need to loose about 40 pounds - I'll drink less beer this summer
Old May 29, 2015 | 03:59 PM
trackadaptor
Aaaaaa
Got me a weee bit of pining fully loaded 2up plus gear 425 pounds from 3,500 - 7,900 above sea level
I wish I understood the TTS Program - I have all the cables ...
Old May 29, 2015 | 04:11 PM
senna's Avatar
senna
Bob tuned mine as well, never pings, never runs hot and gets 40+mpgs when cruising.
