My Engine Build 102hp 113tq
Old May 21, 2015 | 10:47 AM
trackadaptor's Avatar
trackadaptor
Talking My Engine Build 102hp 113tq
Started life as a 2009 FLHTCU 96" 75hp 85tq
After 69,000 miles it was time for new:
As Pictured: 103ci 102hp 113tq - Look at the curve
GREAT for a all around tourining high milage bike Cheaper than a Stage 4 kit
I maintained the Stock Throttle Boddy , and Injectors - read way to many folks not to happy with thier Satge 4 kits
This is the Meat of my changes: Clutch Spring was changed to the SE, Push Rods etc............
Screamin' Eagle Pro CNC Ported Factory Heads with Valve Upgrade
16500013A
BIG BORE PISTON KIT
22144-08B
SE255 Cams
FLH757 Bassani 2into1
Screamin' Eagle Ventilator Performance Air Cleaner Kit-29915-09
Screamin' Eagle Billet Cam Support Plate with High Volume Oil Pump-25282-11
Automatic Compression Release-28861-07A
Part Number 28861-07A
Old May 21, 2015 | 11:43 AM
RevBlk's Avatar
RevBlk
Impressive. Looking at something similar for my bike next winter. Congrats on a well built engine.
Old May 21, 2015 | 12:02 PM
Joker65's Avatar
Joker65
Looks good... doing just what that build should do!!
Simple and strong, getting everything you need for a great bagger build!
Congrats, well done! Have fun with your new motor!!
Old May 21, 2015 | 12:22 PM
Softy 103's Avatar
Softy 103
16500013A
BIG BORE PISTON KIT
22144-08B
SE255 Cams
New pistons , heads, cams, and intake and exhaust you basically have a stage 4. Most of the time a stage 4 will put out a lot better #s than what you have posted. I did the same as you 103," cams, heads, intake and exhaust, stock throttle body and injectors, 122lbs. Tq. and 118 hp.
Old May 21, 2015 | 12:35 PM
SBates08's Avatar
SBates08
His choice in cams is pretty much what limited him in that aspect but still decent numbers. Should pull really well.
2010 Limited with some stuff
Old May 21, 2015 | 02:06 PM
2013_FLHTK's Avatar
2013_FLHTK
I wonder how much better my bike would run with just flat top pistons and the se-255 or se-585 cams?
Old May 21, 2015 | 05:07 PM
0ldhippie's Avatar
0ldhippie
That is really good for 255s. Hope ya got a good tune for guard against pinging.
Old May 21, 2015 | 06:38 PM
Keithhu's Avatar
Keithhu
Post your chart!
Old May 21, 2015 | 09:18 PM
2009blackpearle's Avatar
2009blackpearle
Default same engine parts with 585 se cam
Old May 21, 2015 | 10:09 PM
Softy 103's Avatar
Softy 103
Originally Posted by Keithhu
Post your chart!
Here it is.
