touring pack brake lights needed
Old May 30, 2015 | 08:28 AM
craigffb's Avatar
craigffb
Originally Posted by xcbullet
Yes awesome & that should of came on all tour packs or something like it. Not sure if that would fit mine, it says my year but king. I'm guessing the road king & elactra glide classic the same.
When they say KING they mean King Tour Pak...ie: the big one. There are 3 different Tour Paks: King, chopped, and razor. The light you are talking about fits a King tour pak.
Old May 30, 2015 | 08:41 AM
rdam's Avatar
rdam
On a 99 Electra Glide the first thing I'd add is a Bright *** Light (BAL-1). Everything else is supplemental to that. It will burn your retinas.
If you're not familiar just do a search.
Old May 30, 2015 | 08:51 AM
xcbullet's Avatar
xcbullet
I'M leaning towards the custom dynamics with flash brake & steady running. The picture of that orange Harley on the mutazu site is what I'd like to paint mine next winter, is it called Harley orange or something else?
Old May 30, 2015 | 01:10 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Get a stick on LED smoked tube light strip that runs from one side of the bottom of the tour pac to the other side and mount it just under the lip of the pac. A very small hole is needed to run the thin wires into the pac. Get a good LED tube and it will be almost invisible when off but bright as hell when activated. If I uncover my bike tomorrow, I'll snap a picture for you.
Old May 31, 2015 | 10:16 AM
bill from tn's Avatar
bill from tn
This is my setup on a road glide custom. I added a tour pac for storage on long day trips and comfort for my wife.
I used a custom dynamics truflex strip. I mounted it under the lip on the bottom section of the pac. It gets weather protection from the top section and I have never had it leak in over a year of use. It has weathered some pretty heavy rains.
The center section is a run/brake light, the outer sections are turns and flashers. I wanted some lighting up high on the bike, the standard HD lights are low and centered.
This strip is very bright and noticeable. Add a flasher and you will be seen by anyone looking your way. Two small holes drilled in the tour pac is all that is needed for wires.
I wanted a clean look. I did not care for the abundant chrome on the ultras, especially since I was putting this on a road glide. Add the custom dynamic side lights for a really nice package.
Note, the attached photo was taken with the sun shining directly on the bike. With the sun overhead or at night it is much brighter than it appears in the photo.
Old May 31, 2015 | 10:22 AM
xcbullet's Avatar
xcbullet
Nice clean look for sure.
Old May 31, 2015 | 12:42 PM
bklynbob's Avatar
bklynbob
Do ya have a rack on the pack?
Old May 31, 2015 | 06:39 PM
xcbullet's Avatar
xcbullet
Yes there is a rack.
Old Jun 1, 2015 | 01:11 AM
bklynbob's Avatar
bklynbob
Ive posted this a few times ,it's a Sound Off Signal Ghost brake/ tail w/ built is 5 pulse flasher.I mounted it on my airwing rack.
Old Jun 1, 2015 | 07:32 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Like others have said before, it's a very expensive mod.
I usually only have my tourpak on when traveling or when my MOST Precious package, my Wife is riding!
With all my LED lights (side markers, rack light, tourpak, and CVO stock brake lights) and brake modular, AND being a bright *** yellow.
Some folks still can't see me!!!
YB
Note: sorry bout it being upside down.
