This is Baffling!
Old May 28, 2015 | 11:33 PM
Ibfuelish's Avatar
Ibfuelish
Default This is Baffling!
My attempt at humor, I know is lame.
I have a set of V&H Dresser Duals. Sound great to me...But, I have a penchant for modifying something. I pulled the baffles out of these duals and thought to myself..."What would happen if I cut the venturi end off the baffle (end closest to engine) Slid a thin walled pipe over the first 1/3 of the baffle (again end closes to engine) tacked it in place and rewelded the venturi back on?
Has anybody done this? If not, what would be your expectation of the outcome as far as sound, fuel management issues, etc. and please back it up with some mechanical knowledge.
Thanks!
Old May 29, 2015 | 01:20 AM
Ibfuelish's Avatar
Ibfuelish
Ok, so the request for mechanical knowledge comes across a bit douchey. Sorry. Just didn't want a bunch of speculation. I can conjure up that on my own quite nicely.
Mike!
Old May 29, 2015 | 08:50 AM
CSMHOG's Avatar
CSMHOG
I'm not trying to come across the wrong way here but I'd think you would have asked this question before you performed the modification. But now that you've done it, you would now the expert on this subject. Also, what slips on did you do the modification to?? I didn't think the V&H dresser duals had baffles in the headers.
Old May 29, 2015 | 12:22 PM
Ibfuelish's Avatar
Ibfuelish
Ok, just some miscommunication here. I haven't done anything yet. I was cleaning and polishing and decided to remove the two screws that hold the end caps on my V&H slip ons. I pulled the end cap out and of course the baffle came with it. This is where I pondered the "What if..."
Old May 29, 2015 | 12:32 PM
bigskyroadglide's Avatar
bigskyroadglide
If you close of a third of the baffle in my opinion that would potentially increase back pressure
While cutting the baffle in half and reinserting would decrease back pressure (assuming the end cap screws would hold the baffle in the muffler)
Dont think this would migrate using fuel mgmt and may make it harder to tune.
S&s spends a bunch of money on r&d, not certain i would try to out guess them In this area.
MY two cents which is probably more than my post is worth.
Old May 29, 2015 | 01:06 PM
grapeapes's Avatar
grapeapes
Do you have a picture of said baffles? I know V&H have both an open baffle (cheese grater straight thru) and a quiet baffle (half wrapped, and the end near the motor is capped to force thru several smaller holes.)
Old May 30, 2015 | 03:59 PM
Ibfuelish's Avatar
Ibfuelish
They are the open baffles, cheese grater straight through. I love their sound. I'm just wondering what if...
unlucky13
Exhaust System Topics
Sep 30, 2014 10:18 PM
slimjim1976
Apr 1, 2014 11:07 AM
clembo
May 26, 2012 04:45 PM
fulldraw00
Sep 19, 2011 01:09 PM
drrandall1
Apr 18, 2008 09:03 PM
