Baffle replacement
Old Apr 17, 2008 | 10:20 PM
drrandall1's Avatar
drrandall1
Default Baffle replacement
This is an easy job right? I have the Rinehart true duals and had the original baffles replaced with the performance baffles. The sound is louder but I get an annoying rattle type sound on decel. I am thinking of ordering the www.bigcitythunder.com baffles instead. I was just going to change them myself. Do thebaffles just slip right out and do the new ones slip right in? I had the dealer do them when I did the duals, race tuner, and download.
Old Apr 18, 2008 | 10:01 AM
drrandall1's Avatar
drrandall1
Default RE: Baffle replacement
bump. No one here has replaced their baffles?
Old Apr 18, 2008 | 11:24 AM
mphamrick's Avatar
mphamrick
Just replaced the baffles on my Vance&Hines, mine had a single screw on the end cap and there is another one under the heat sheild that holds the baffle in place, then it slips out. Be sure to use some lock tight on the screws when you install them. I used the blue lock tight so if I needed to remove them again I could.
Old Apr 18, 2008 | 02:10 PM
drrandall1's Avatar
drrandall1
Actually I just talked to big city thunder. I guess there baffles go inbetween the head pipe and the muffler. You have to drill a hole too. Hmmm. Might be a pain in the a**.
Old Apr 18, 2008 | 09:03 PM
ebeattie's Avatar
ebeattie
mphamrick, how hard was it for you to remove the heat shields? U have to remove the pipes from the bike? I have a set of big shots that have quite baffles installed and want to put the regular baffles in.
Taterdog
May 9, 2011 09:38 PM
thelawnmowerman
Mar 24, 2011 03:17 PM
qwiktripp
Dec 26, 2009 05:37 PM
vettedog72
Feb 24, 2009 09:47 PM
dumbjarhd
Jun 9, 2007 01:33 AM
