Rinehart Baffles
Old Feb 24, 2009 | 07:22 PM
vettedog72's Avatar
vettedog72
Default Rinehart Baffles
I have decided that the Rinehart TD baffles don't come out! I took the end caps off and tried to loosen the baffles by putting a pribar down the tube and ricking the tube using the pry bar. No Luck. I ran the motor for a while to heat the mufflers up and still no luck. I rand the bike 75 miles or so with the end caps out and then tried to loosen them; again, no luck. I wanted the baffles out to make noise in a parade and found the removing the end caps gave enough noise. I have decided to leave the baffles alone. HD dealer said sometimes the muffler has to be removed and the baffle driven out.
Old Feb 24, 2009 | 07:54 PM
deni's Avatar
deni
They sure sound stubborn. When you finally get 'em out, butter up the ends w/ copper anti-seize. I can assure you the baffles are easily removable as I've had mine in and out 4-5 times.
The install calls for RTV silicone at the muffler/header joint. This doesn't affect the baffle but maybe the installer mistakenly used RTV on the baffle. Otherwise they're just seized up.
What ever you do, don't bend up the baffle.
By the way, why are you removing the baffles ?
Good Luck.
Old Feb 24, 2009 | 09:47 PM
vettedog72's Avatar
vettedog72
I was in a parade where more noise was OK. It was not intended to keep them out. If I could get them out I might try the fiberglass wrapped sound as well as other baffles.
bmaier
Jul 13, 2011 07:49 AM
aquaelvis
May 4, 2011 08:04 PM
nmaineron
Exhaust System Topics
Apr 21, 2011 01:51 PM
bloomington g
May 29, 2010 10:48 PM
falsealarm
Jul 9, 2007 07:58 AM
