Saddlebag lock broken
Old May 29, 2015 | 06:47 AM
Badass Bagger's Avatar
Badass Bagger
Default Saddlebag lock broken
The lock on my 13 RG is broken, it won't lock just keeps turning. The latch works fine. What is the cost to fix it. I just picked the bike up Friday. Would the warranty cover it? I believe it was broken when I bought it.
Old May 29, 2015 | 06:55 AM
Weavr99FLHT's Avatar
Weavr99FLHT
With the bag open, you can watch the lock as you turn the key. There is a cam hook with a tab to prevent spinning see if that is turning.
I replaced a lock - $50 and Two came in the package with 2 keys. Take the black cover off your key and you will find a 4 digit key code. Give that to dealer when ordering the lock and will be keyed to match.
53710-93 I think
Old May 29, 2015 | 06:57 AM
riteway's Avatar
riteway
Never had the lock itself break BUT i have had the lock screws come loose.Not sure about warranty? You should just take it apart and take a look.No big deal.Something like that could be an EZ fix not worth taking to the dealer/Leaving it/time for them to look at/fix/then picking back up. Just take a quick look...Now if its under warranty then maybe..
But best to figure out what makes your bike tick...Just sayin..
Look at your manual to see what it looks like...Or check the many online parts manuals like Ronnie's
Good Luck...
http://partsfinder.onlinemicrofiche....IDE-ULTRA-(KGM)
Old May 29, 2015 | 06:59 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
I Would say yes.
Bring it back to the dealer, simple fix on their dime. Out of courtesy, they should fix, in & out quick since it's not been a week.
If. Under warranty, there s a $50 deductible. Which if I am correct, is more expensive then the part itself.
YB
Old May 29, 2015 | 07:13 AM
Iceman24's Avatar
Iceman24
Like others say...easy/cheap fix, but see if dealer will cover 1st. One of mine came apart and I dissected the other side to see what was required to repair. Ended up needing a small spring & I bought at Ace HW for under $1. These locks/latches are pretty simple...just need to know how they're built. Enjoy!
Badass Bagger
Thanks guys, I will take a look at it. If I can't fix it then they get to. Just wish I was told about it.
Old May 29, 2015 | 09:14 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
The lock cam is held on with one nut. It's like $4 for the cam and nut. Easy fix...... USE blue Loctite
Here's your part numbers
Cam 90682-93
Nut 7586
Old May 29, 2015 | 09:18 AM
cass's Avatar
cass
i had an issue with my trunk lock on my 2013....couldn't get the key back in after i unlocked it one day. really weird, the slot wouldn't line up so the key couldn't go back in. since i could still use the trunk latch i just waited for service and had them fix it then. was under warranty so no problem for me.
Old May 29, 2015 | 09:20 AM
From_Behind's Avatar
From_Behind
If it still has factory warranty coverage (which it may - it's a '13), there's absolutely no deductible. That's only the ESP that has a deductible.
Old May 29, 2015 | 01:10 PM
09 YELLOWBIRD
You are absolutely correct. I was talking about ESP warranty but didn't type it in there.
My bust! Didn't have my Java yet!
YB
Pyungshin
Aug 16, 2014 04:24 PM
CGLTD
Apr 17, 2014 09:21 AM
hevis1
General Topics/Tech Tips
Aug 5, 2013 07:21 AM
hevis1
May 26, 2013 08:54 AM
danmo
Jun 1, 2010 01:13 PM
