2 into 1` Nightstick muffler
Old Jun 5, 2015 | 03:21 PM
bigheadted's Avatar
bigheadted
Default 2 into 1` Nightstick muffler
I am wondering if anyone knows if a 2-1 Nightstick would work in a dual application.
In other words can I get 2 of these slipons and use them as a direct bolt on to replace my stock slipons ??
I like the disc setup and am a cheapskate, I can find plenty of them for well under a 100 bucks each and figured it could potentially be a frugal way to get a pair of this type of slipon.
I know the lettering would be on the inside of the left one if they work and could care less.
Is the diameter of the inlet different ??
Anyone Know ????
Can anyone with one of the 2 into 1 mufflers measure from the inlet end to the first hanger bolt hole ?? Purdy Please ???
Old Jun 5, 2015 | 04:10 PM
p51bombay's Avatar
p51bombay
chances are there will also be a notch for axle clearance that would be on the outside.
Old Jun 5, 2015 | 04:15 PM
bigheadted's Avatar
bigheadted
I see no dimple or notch in the photos I looked at but can someone confirm ??
Also overall length appears to be 34" and inlet is 1.75 " so it could work ??
I wonder it the distance between outlet of headpipes/inlet of muffler to muffler hanger bracket is the same ???
Anyone verify ??
Old Jun 5, 2015 | 04:52 PM
smitty901's Avatar
smitty901
The night sticks come for duals also.
I have Night sticks on my 2013. and had them on my 07 and 2011.
Old Jun 5, 2015 | 05:13 PM
themensh's Avatar
themensh
I have two night sticks on my bike. No axle dimples and the screaming eagle script is inside and on outside of each on.
Old Jun 5, 2015 | 05:41 PM
0ldhippie's Avatar
0ldhippie
I thought I read/heard somewhere they were longer than the dual ones?? I would get a measurement before buying. That said I got my two SE Fatshoz for $200 on the forum. They were like new.
Old Jun 5, 2015 | 05:50 PM
skratch's Avatar
skratch
the nightstick 2-1 would not work (easily) as a dual application. the header pipes are different (the attachment point is in a different area) , and the muffler is longer. the rear hanger bracket would not be in the proper position for mounting, and the rear of the muffler would be sticking out way too far. would be a new take on cholos
Old Jun 5, 2015 | 09:37 PM
bigheadted's Avatar
bigheadted
Well scratch this brainfart !!! I just measured a couple sets of slipons I have and they are much shorter than the 34" listed length of the single one.
That is what I get for thinking and planning before going in the garage !! Thanks for the replies all.
If anyone has a pair of these for sale even not pristine ones let me know.
Old Jun 6, 2015 | 05:38 AM
smitty901's Avatar
smitty901
Having had both the HD Fatshoz's and the Night sticks I liked them both. I added two disk just for something to do . They come with 10 from the dealer.
Just for those that have never seen the inside of them.
Attached Thumbnails 2 into 1` Nightstick muffler-100_1840.jpg   2 into 1` Nightstick muffler-100_1841.jpg
Spookymason
Nov 2, 2013 06:10 PM
kevdog
Nov 17, 2010 03:20 PM
blackbob
Jun 28, 2010 04:58 PM
skyking
Nov 10, 2008 10:23 AM
miragetsi
Jun 30, 2007 04:10 PM
