For the front lever, I used a bolt and a "Nylock" nut. Granted, it's not the snazziest-looking equipment but the nylock nut stays on without worrying about locktite, etc.
I also used nylon "spacers" on the bolts front and rear, probably didn't need them, but I put them on anyway.
For me, function is more important than form:
I can't answer with a direct torque value, but tighten until the heim joint binds...then back off enough to free it up.
'03 UltraClassic. The 3rd shift rod is a charm. The 2nd one was a chrome Kurysomething and it broke after about 10k miles. I replaced the ends with aircraft heims and it has been good until now.
I had the jam nuts to the end of the threads. How do you know it is adjusted correctly? I took it for a test run and it seemed to work fine.
What goes wrong with the stock connectors? They seemed pretty solid.
I know this isn't rocket science, but I would hate to screw something up.
Thanks.
it's adjusted correctly if your shift lever is in a comfortable position for you. kind of a 2 part adjustment. first is by the splines on the lever itself. then the second is by the threads on the shift rod. that is a finer adjustment. moving it one spline can make a huge difference.
what happens to the stock ends is that the ball will come out of the socket resulting in what you saw in the op's picture
