So my shifter linkage fell off on the highway
Old Jun 6, 2015 | 10:39 AM
Ron750's Avatar
Ron750
How
Originally Posted by skratch
Here is the SAE equivalent that was posted by Iamswutiams.
2 ea heim joints 5/16-24 right hand (http://cgi.ebay.com/ebaymotors/ws/eB...m=280249330109)
2 ea 5/16-24 x 1 in hex cap screws (i used grade 5 stainless, not that much stress where you'll need grade 8, but you can if you want, but it costs more)
2 ea 5/16-24 jam nuts
1 ea 5/16-24 nylon lock
https://www.hdforums.com/forum/touri...mod-today.html
I just ordered the Heim joints from DK customs. I wasted a 1/2 hour looking for them at Ace Hardware and Tractor Supply. They may be a little more, but DK has a good rep, and I am hoping they are made in USA.
http://www.dkcustomproducts.com/Pair...?categoryId=-1
Old Jun 6, 2015 | 10:57 AM
Gwaxley's Avatar
Gwaxley
Originally Posted by SBates08
That sux when that happens. I see a reflection of the Gremlin in your horn cover.
2010 Limited with some stuff
That funny I would have not noticed the reflection.
I need my shifter and tires and brakes and little gremlin bell and a few other things, maybe that's why I check it regularly.
Old Jun 6, 2015 | 12:23 PM
05flhtbob's Avatar
05flhtbob
The Heim joints make the shifting so much smother too
Got mine on Ebay for under $7 bucks
Old Jun 6, 2015 | 10:20 PM
ebigfish's Avatar
ebigfish
Originally Posted by OldEnuf2NoBtr
That is one of the first things I change on my bikes soon after I take delivery.
Ditto!
Old Jun 6, 2015 | 10:30 PM
rperk60's Avatar
rperk60
Whats the cost to change.
Old Jun 6, 2015 | 11:25 PM
Fishrrman's Avatar
Fishrrman
Pics of my replacement below.
For the front lever, I used a bolt and a "Nylock" nut. Granted, it's not the snazziest-looking equipment but the nylock nut stays on without worrying about locktite, etc.
I also used nylon "spacers" on the bolts front and rear, probably didn't need them, but I put them on anyway.
For me, function is more important than form:
Attached Thumbnails So my shifter linkage fell off on the highway-front-joint-2.jpg   So my shifter linkage fell off on the highway-rear-joint.jpg
Old Jun 6, 2015 | 11:28 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Anywhere from $20-150 depending on what you want.
Old Jun 6, 2015 | 11:45 PM
bigheadted's Avatar
bigheadted
I think I spent 10 bucks simply using stock linkage rod and some heims, nuts,washers and nylocks.Been on 3 bikes now.
Old Jun 11, 2015 | 07:01 PM
Ron750's Avatar
Ron750
I swapped out the stock connectors for the Heim joints, but I have some questions. The original bolts had yellow loctite on them, which is stronger than blue. I used blue on the front, and a nyloc nut. On the back I just used blue loctite. How tight should you crank on the bolts? I just snugged them with a combo wrench.
I had the jam nuts to the end of the threads. How do you know it is adjusted correctly? I took it for a test run and it seemed to work fine.
What goes wrong with the stock connectors? They seemed pretty solid.
I know this isn't rocket science, but I would hate to screw something up.
Thanks.
Old Jun 11, 2015 | 07:26 PM
sbeast's Avatar
sbeast
on mine, the retaining ring on the ball joint failed.
