p0113
Old Jun 23, 2015 | 07:26 PM
Rustyg500's Avatar
Rustyg500
New ECM and voltage regulator needed? Find a new dealer pronto. Take Caberto's advice then if no positive results Replace the IAT yourself. Save labor costs.
Old Jun 23, 2015 | 08:30 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Another thing to check besides the TCA connector behind the air cleaner: on top of the intake is a vacuum hose fitting that is unused. There should be a rubber cap on it. If the rubber cap is missing, can cause a P0113 code. If cap is missing and you replace it, change spark plugs and reset the idle (procedure is to turn ignition on then off 4 times).
Just resolved same issue on friend's bike doing all of the above.
Sent from my iPhone using IB AutoGroup
Old Aug 25, 2015 | 11:01 PM
johnnythrottle's Avatar
johnnythrottle
My 2005 FLHRSI has encountered code (po113) also. Engine light stays on then off consistently. Only 12000 Miles on this Road King and it runs great - my shop is telling me that the IAC Motor needs replacing after they diagnosed this code - not sure what their rationale is around that and reading above sounds like it could be a wiring problem to the IAT Sensor.
Old Aug 26, 2015 | 06:49 PM
Rustyg500's Avatar
Rustyg500
P0113 indicates the IAT sensor is open. Either it is bad, unplugged or there is a wiring issue. I would check and make sure it is plugged in and properly placed. If all is correct I would replace it. My 2002 Electrical Diag manual says it is under the gas tank right side. It has two wires feeding it. One is Light Grey/yellow. The other is black/white, Not sure if it is the same for your 2005 however.
KennyPowerz
General Topics/Tech Tips
Jun 6, 2018 10:30 AM
JEdwardsJr
Sep 27, 2014 06:52 PM
Stiggy
Electrical/Lighting/Alarm
Jul 10, 2013 05:47 PM
BluBeaSSt
Nov 25, 2012 11:17 AM
rmwill
Jul 8, 2006 04:18 PM
