Has anyone seen anything like this before?
Old Jun 9, 2015 | 03:01 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
When push rods are perfectly straight and show no sign of wear, you can use stiffer springs and significantly increase the RPM of the engine; this is my experience.
When you have longer valve stems, greater cam lift, new valve keepers, the 'inside' of a rocker touching the edge of a valve retainer then the swing of the rocker changes and may call for more clearance between the push rods and engine ports.
With stiffer springs and higher RPM the push rods can slightly deform; interference may occur at a specific regime and cause damage because the effort will no longer be aligned.
IMO this broken rocker stand looks like the design work of a beginner. There is plenty of material for identification data and very thin alloy bushings around the rocker shaft.
Old Jun 10, 2015 | 12:03 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by bagman1
I think his point was the more mods made to go faster, the less reliable and less longevity you have.
Exactly.
Some guys don't understand examples.
And most of us don't have the $59 thousand to buy a top fuel engine anyway....
Just sayin'
Old Jun 10, 2015 | 03:31 AM
Guntoter's Avatar
Guntoter
I am guessing the Nascar looking springs is the problem. Like a previous poster stated, the forged rocker stands are necessary here. The originals broke due to high lift pressures.
M8124
Milwaukee Eight (M8)
Jul 9, 2020 03:31 AM
dlynch851
EVO
Jun 9, 2016 04:28 PM
txphatboy
Engine Mechanical Topics
15
Feb 17, 2016 10:29 AM
cycojon
Exhaust System Topics
Nov 30, 2011 09:01 PM
1931jamesw
Aug 18, 2011 01:34 PM
