Maybe some of you serious builders will have some input on this (see the attached picture) This is what is left of my buddies rocker arm assembly on his 03 RK. Approx 2000 miles on a new top end build. We were riding last Saturday when he had a sudden loss of power followed by a lot of noise in his top end. We trailered the bike back to my place, tore into the top end and this is what we found.
He is running 590 lift cams with 97" S&S juggs and pistons. All the head work was done by a very reputable shop in the area who has been around for over 30 years. I felt the valve spring set up looked like something out of NASCAR but he says he used what was appropriate for the lift of the cams. We pulled the heads and took them to have them checked out. My initial thought was it might have been some kind of spring binding on that particular valve that caused it to freeze up either that or a lifter froze up but I'm far from any kind of motor guru. The shop who built the heads pulled them apart and everything looked fine. He thinks it must have been a bad casting of the rocker stand. I'm hoping that is the case but have never seen this before.
I am no wrench but hate to read this as my bike is having an S&S 97" going on it. Sure hope I am not sorry. I do know that if anything were to happen my Indy would make things right but I better try to think positive.
Build an 8000hp top fueler with ALL the best parts, pray it holds together for 1/4 mile.
Build an 800hp Cup car, poray it holds together 500 miles.
That's why I keep a stock + stage 1.
The OP was talking about a motorcycle engine. Suddenly you are talking "top fueler" and "Cup car." Not everyone want to keep it Stage I and live in your comfort zone.
I think his point was the more mods made to go faster, the less reliable and less longevity you have.
